A few questions first:
1) Does this effect the functioning of the "solo" at all? (ie is the light on always but without effect and can you select solo using the pushbutton?) We need to determine whether or not the problem is a funcitonal one or just the indicators being lit when they shouldn't be.
2) Are there any other symptoms at all? Any other lights effected at all or any functions not working as expected?
I will look up the prints for this, but I need to narrow down the search a bit. Gaining access to the board is not quick as all of the knobs need to be removed and all of the control nuts removed as well. If we can narrow this down a bit, you may be able to avoid that.
Please post up the info requested and I'll pull up the prints.
Thanks,
Dan
All solo lights stay lit regardless of position of solo buttons. With all channels muted, no red lights come on. This happened after reseating all ribbon and molex connectors. Was working fine when I broke it down to try and "heal" the intermittent problems that seemed to be being caused by corrosion on ribbon cable connectors. I'm trying to narrow down the spectrum of things that might have been changed through this process. I can't seem to locate a diagram showing which ribbon cables go where?
