Question about HP Pavilion a705w PC Desktop
Memory card reader for hp pavilion doesnt work how do i find drivers or repair
  • Gary
    Gary Nov 07, 2010
    Did it work before and just start having the problem recently?
    Novelist:
  • 124 Answers
If it worked before and then stopped working all of the sudden, it may be that a Windows Update caused a conflict with the driver software for the reader. Try going to the HP support website and see if more recent drivers are available. Start with hp.com and go to the support section. If it never worked and you think it might be a hardware problem, the easiest solution is to buy an inexpensive USB memory card reader. They're pretty simple to use and there are many kinds available.
Posted on Nov 07, 2010
  • 31 Answers
Posted on Oct 14, 2011
Built-in memory card reader doesn't work
It's a common problem in a OS upgrade. Is your OS 32 or 64bit? Is that the only thing that out of service? In Device Manager do you show ANY Unknown Devices? Is the Card Reader Listed? post results.
Jan 26, 2013 | HP Pavilion g6-2210us Laptop PC
What sd ms xd reader driver is best to download for HP Pavilion Slimline s5122f?
Any USB memory card reader that supports your memory card is OK. Most USB memory card readers will support serveral SD memory card types.
Sep 10, 2011 | HP Pavilion Slimline s5122f PC Desktop
My hp pavilion dv4000 cant read SDHC memory cards
you need to reinstall the drivers of the memory card reader
You can download the drivers via below mentioned links
Texas Instruments Media Card Reader Driver
Direct Download:
sp33439.exe [1/1, 6.76M]
Do post back if you require more assistance, Thanks for contacting Fixya
Regards, Bilal
Jan 12, 2011 | HP Pavilion dv4000 Notebook
The card slot reader is not working/ doesn't recognize card when inserted. No response. How do I activate it? I'm running windows 7 and it's an 8 and 16gb sandisk micro sd card w/adapter. It's for my...
go to control panel -> system and security -> system -> device manager. that has a list of all the hardware on the computer, look for any items that have X ! or ? next to them. Could be that you don't have a driver loaded for that device.
Dec 23, 2017 | HP Pavilion dv7-1245dx Notebook
Hp pavilion pc sd card reader not working i
vista just had a update for the SD card reader. Go to Microsoft website and update the driver. FYI Vista is also known for having some problems with the SD card readers in the past
Jan 03, 2010 | HP Pavilion dv1000 Notebook
My Hp SD card reader doesn't work how can I make it work again?
Did you insert the memory card properly? because if your memory card is not inserted properly, the SD card reader may seem not to work. And if probably the problem is from the SD card reader slot, then you have to give it to an engineer for repair or better still take your laptop to Hp customer service center for repair. Thanks
Sep 24, 2009 | HP Pavilion dv1000 Notebook
My hp pavilion ea8290 cant see memory cards bigger than 2gig
Go to the link below and see if a new driver has been released or a newer driver than what you have installed for your card reader.
http://welcome.hp.com/country/us/en/support.html
Sep 13, 2009 | HP Pavilion zd8000 Notebook
We have an Hp computer. The memory reader in the
Hi Larry,
There are a few likely scenarios that would cause your card reader not to work.
1. The cable inside the computer that connects the front-panel card reader to the motherboard has come loose. You can check inside the case to make sure the cable is tight and connected. You should do this with the computer turned off, and turn it on when you're done.
2. The card reader itself has gone bad and stopped working. If this is the case, you'll need to either contact the manufacturer for repair, or you can go out and get yourself an external USB card reader for cheap.
3. The card reader is functional, but there's something wrong in the operating system that prevents the cards from being read, because the operating system doesn't know how to address the card reader. This can usually be fixed by re-installing drivers and software for the card reader.
May 18, 2009 | HP Pavilion a705w PC Desktop
Sd driver not working
try to insert the sd card slowly and watch the blue light if starts to blink that means it is reading your memory card then that must be the depth u can insert your memory card for the reader to work. hope this is helpful
May 12, 2009 | HP Pavilion dv1000 Notebook
SD card reader
1) There is SD card reader on pavilion dv 1000, so you need adapter in which you insert mini SD card to make it SD
2) If you have that adapter, check adapter. Maybe it's broken.
3) If your card is biger, like 2GB or higher you may try updatenig drivers (I read on one web page: " There was a software update for support of reading and using higher memory SD cards, for my pavilion ZV5000, on the HP Software update website." )
May 31, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion a705w PC Desktop Logo
296 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
