Question about Philips 32PT5441/37 32" TV
I tried connected my XBox 360 HDMI components to my Philips 32PT5441/37. When I did that and turned it to "CVI" it shows my screen but its not positioned right and it keeps moving up and down. What do I do?
  • Philips Master
  • 1,210 Answers
In many cases there is nothing wrong with the TV. You may need to reread the handbook for operating setup on picture centering in the Xbox instruction book. In some rare occasions you may need to upgrade the Xbox with a USB upgrade connection. Thanks for asking and show a few hands of support!
Posted on Nov 07, 2010
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
Turned xbox on. tv said "not supported mode". turned off . completely unplugged, re plugged, switched hd/tv switch, no results. what is the problem?
try using a xbox 360 HDMI lead, you can buy one here:
http://www.play.com/Games/Xbox360/4-/12361467/Official-Xbox-360-HDMI-AV-Cable/Product.html?_%24ja=tsid:11518'cat:12361467'prd:12361467
Mar 22, 2011 | Microsoft Xbox 360 Console
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
My xbox has color problems
Component, HDMI? May want to check cabling. Having the component cables plugged in incorrectly can create color problems.
Sep 03, 2009 | Microsoft Xbox 360 Console
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
No video or sound.
This is usually caused by a bad graphics card on the xbox. It isn't always detected by the xbox motherboard. I'm sorry to say, but it's pretty much toast unless you can find a repair guy in your area to solder on a new vga card.
May 07, 2009 | Microsoft Xbox 360 Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
CVI connection
On a Philips TV the only way I know to switch to any of the inputs is by scanning using channel up or down. This model is capabable of 480P input only at the CVI/Component input. This is not a HD television. It is only a EDTV (enhanced definition) if you try and input anything iver 480P IE: 720p or 1080i, the double image and/or lines is what you will get.
May 27, 2008 | Philips 27PT8302 27" TV
Philips 32PT5441/37 32" TV Logo
128 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
