Question about Samsung P50HP 50 in. LCD TV
Samsung hps5053 picture goes black but sounds stays on ,just started acting up about a month ago.also picture comes back sometimes quick other times 2 to 4 minutes later
  • 3 more comments
  • mtssbarrios Nov 07, 2010
    what it,s gonna cost me to get this fixed
    how much is it gonna cost me to repair it
    did you get my reply
    my zip is 90602 i appreciate the help thanks Mark
  • mtssbarrios Nov 08, 2010
    hey Tim thanks for all your help
  • 4,889 Answers
This is a 100% sustain board related problem. I have seen this a million times before. All you have to do is to replace the damaged capacitors on the sustain boards. It is caused by the inability of the damaged capacitors to carry on their rapid charge/discharge cycles. As for doing it yourself, it depends on your prior experience in working on high voltage electronics. The several thousand volts of residual voltage can cause permanent disability/death if not handled carefully.
Sai.
Posted on Nov 07, 2010
  • eagle338
    eagle338 Nov 08, 2010
    The replacement capacitors will not cost you much 10-20$ at the most. Expect a service charge of about 100-150$. I can get you a list of techs in your area if you can get me your zipcode.
    President:
  • 2,777 Answers
This is a problem with the video board in your TV, it is starting to fail. I have seen it many many times with TVs like this.
Do you think you want to try and do the repair yourself? It is definitely not easy by any means, but if you have done advanced TV repairs in the past it is possible...
Please let me know, also I can help you find someone in your area that can fix this for you if you wish. Just let me know!
Just reply to my answer here and I can continue to help.
Thanks,
Tim
  • 3 more comments
  • Tim Grayson
    Tim Grayson Nov 07, 2010
    Yes I got your reply here, sorry about the delay. Had to run and grab something to eat real quick, back now though. It looks like the board itself is around $130 and the labor should be about the same. I would say under $300 to get it fixed up if you can find someone honest and reasonable in your area...
    Let me know your zip code and I can find someone for you
    Tim
  • Tim Grayson
    Did you see mine there?
  • Tim Grayson
    Oh sorry, saw your zip code there.
    Ok Try:
    Pauls TV
    500 North Harbor Boulevard, La Habra, CA (562) 448-9800 ()
    and / or
    Whittier Radio / TV
    13602 Ramona Drive, Whittier, CA(562) 698-6756
  • Tim Grayson
    Oh and also:
    J&J TV Service
    9209 Whittier Boulevard, Pico Rivera, CA (562) 695-0714 ()
  • Tim Grayson
    Tim Grayson Nov 08, 2010
    No problem, if possible please come back to the question here and click the Accept This Solution link under my answer... that way it shows that I helped you out here.
    Thanks
    Tim
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
Bottom half of picture cuts out?
This is most likely a "cold" solder joint on one of the components, i.e. capacitor, inductor, ect. If you are handy with a solderiing iron and disassembly and more important reassembly, then you could reflow the cold joints. I hope this helps. Good luck :)
Jun 16, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Samsung P50HP 50 in. LCD TV Logo
171 people viewed this question
Jerry Greenberg
Jerry Greenberg
