Question about American Range AF40 Deep Fryer
This has a Robert Shaw gas valve, the pilot light lights but when you let the button up it goes out no matter how long I hold it down
  • American Range Master
  • 43,501 Answers
The power pile thermocouple has gone bad and needs to be replaced.... that is what sends power back to the gas valve to hold it on...
heatman101
Posted on Nov 07, 2010
Pilot goes off as soon as I release the button
You need to hold the button down for about 3 mins. If it goes out after that long the thermocouple is probably bad. Look at how long the wire is from the pilot light to the gas valve. They come in different lengths.
Jan 18, 2016 | World Marketing Kozy-World 3 Plaque...
When you push in the gas the red button the flame will not stay on
CTRL Z TV ' Volume 1: Introduction to the problem and ...
? 4:49
https://www.youtube.com/watch?v=k1qM-ZbYdWo
Dec 16, 2013 - Uploaded by CTRL Z TV
Which will take you from troubleshooting the problem, getting familiar ... Ctrl z TV, Pilot light won't stay lit up, Gas water heaterproblems, Gas water ... If your water heater has a thermal resetbutton, press & hold it for up to 4 ...
Pilot Light Easiest Way to Light it When it Goes Out - YouTube
? 3:06
https://www.youtube.com/watch?v=9bdLuGKaCXI
Sep 24, 2011 - Uploaded by Mixed Martial Animations
Here's a simple solution to a common water heater problem. ... the instructions says turn off the gas valve when lighting the pilot... i... 4 Steps, Set too pilot, hold down red button, push ignitor till pilots lit, ... if the flame will not stay on no matter how long youhold the button down, your thermocouple is bad..
Nov 29, 2015 | Heating & Cooling
How to light pilot light
put to pilot position hold button down for a minute while holding light pilot generator that's where small silver line from gas valve goes under to burners lite there hold for 1 minute (to let pilot generator to get hot) then turn to on position it should work then turn on button on then
Nov 20, 2013 | Teledyne Laars Pool & Spa
Repair robert shaw hot water heater gas valve I have a gas hot water heater with a robert shaw gas valve on it. I get no gas when i push on the red pilot button for lighting. I would like to fix it verses...
Yes you can get rebuild parts for the gas valve. You can go to partsguy.com to order them. Yo can also replace the whole valve for around $80.00.
Hope this was helpfull for you, let me know.
Thanks ,Matt
Dec 10, 2010 | Shaw Robert RS-9420 Thermostat
How do you light the pilot light on the stove? Model 3627391592
A pilot light will be found on natural gas stoves, fireplaces, clothes dryers, water heaters and furnaces. When the gas is turned off, the pilot light will go out on all of these appliances. After the gas is turned back on, you must relight the pilot light before you can use the appliance. Pilot lights are similar so if you can relight the pilot light for a gas heater you can relight the pilot light for a gas stove or any other gas appliance.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions Things You'll Need:
  • matches OR flashlight
  1. Locate the gas valve by following the gas line in the appliance. The gas valve will have a large red button or knob and will be easy to see and will be well marked.
  2. Check for a gas leak by smelling the area close to the gas valve. Listen carefully for escaping gas and do not attempt to light a pilot light if there is a gas leak.
  3. Hold down or press the red button or knob on the gas valve while holding a lit match in front of the opening in the gas pilot line. Continue to hold down or press the red button or knob for several seconds after the gas ignites to allow the thermocouple (the sensor for the appliance's thermostat) to heat up.
  4. Repeat step 3 if the pilot light goes out after you release the button or knob. In most cases, the pilot light goes out because the thermocouple did not have enough time to heat up, so give it a few more seconds.
  5. Make final adjustment of the gas flow to the pilot light by turning the red knob. In some cases, no adjustment other than "on" or "off" will be needed.
  6. Turn on our appliance to make sure the pilot light ignites the main gas flow. Replace any covers or close any access doors to the gas valve.
Hope this help?
Thanks for using fixya.
Nov 23, 2010 | Kenmore Kitchen Ranges
I have what looks to be an old monterey wall-mounted gas heater. the lighting instructions are illegible, and i have never lighted such a unit. i can't even find a model number on it. i need to light the...
look at gas valve, there should be a knob on valve, turn knob to pilot and push button in and hold, the silver tubing coming off valve follow it under the burner, as your holding pilot button down light the endunder burner, if flame appears hold pilpt button down for about a minute then change valve to on and pilot should stay lit, if pilot goes out redo and hold longer, the thermocouple may need to be cleaned.
Oct 27, 2009 | Heating & Cooling
The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Sep 10, 2009 | Coleman (5040B750) Patio Heater
Won't light up
had the same problem, safety gas valve is sticking get a small hammer and tap saftey valve. Just bought a new saftey valve about 3 weeks ago pilot light lite but now flame. I have a blodgett oven made in the 60s. Blodgett is getting away from there swithes that they have been replacing them with a replaceable thermocouple.made by robert shaw. My supplier said that they are not on the market yet. oops! good luck from oswego ny pizza villa.
May 01, 2008 | Blodgett 911-DOUBLE Gas Oven
American Range AF40 Deep Fryer Logo
385 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
starztruck4u
Dan Webster
Dan Webster
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
