Question about Lexmark X1270 All-In-One InkJet Printer
Lex 615 my printer does not power on help
    Master:
  • 638 Answers
First of all just change your power cord and try, and look forward to other problems if any.
Posted on Jun 15, 2008
Not turning on
Try to plug in your printer to a different power outlet and straight to the wall.
If it doesn't work, unplug the power adapter at the back of the printer and check if the LED light is on. If not, then the power adapter would need to be replaced. If it's on, then the printer is defective.
Nov 20, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Reset ink for workforce 615
If you're asking how to replace the ink cartridge in the Epson WorkForce 615, you must first hit Home and then, if there is no error indicating you need to replace a print cartridge, go to SETUP>MAINTENANCE>INK CARTRIDGE REPLACEMENT. This link should help you with the process.
May 08, 2012 | Epson Workforce 615 AllInOne Printer
PAPER JAMS ON EPSON 615
Hi, Disconnect the printer completely from the PC and from power.Reboot the PC.Check through the paper paths for any obstructions and remove any stuck papers manually.Connect printer to power and PC and turn it off and on.Avoid filling feeding tray to capacity.Try printing now. Hope this helps.Thanks!
Dec 26, 2011 | Epson Workforce 615 AllInOne Printer
D-Link DIR-615 Wireless Router not connecting with HP Network Printer
Please use the utility disc that comes with your printer. It will help you to connect your printer to your wifi router.
Or please check if you type the correct SSID of your wifi (Wifi Name). SSID are case sensitive.
Nov 04, 2011 | D-Link DIR-615 Wireless Router
Paper Jam. How do I take this printer apart to remove the paper? Lexmark S305 IMPACT LEXS AllInOne InkJet Printer
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
If you're still experiencing this problem today, please contact Lexmark Technical Support Center so they can rectify this problem right away.
Oct 03, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Gibt es chip resetter software fuer Lex... X6570 ( i am german ) have you chip resetter software for lex....6570
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Lexmark X6570 InkJet Printer
Printer not printing
ok..disconnect from computer..try restarting with hard power down(unplug from wall)..
turn on again..try to do a test page from front panel
Aug 18, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lex T520 BUSY PCL
Check that the RAM is not bad. You can remove it temporarily and the printer should operate on the 8MB built into the main board.
Maximum Memory 264MB Memory Slots 2 Slots non-removable base memory 8MB
Jun 26, 2008 | Lexmark T520 Laser Printer
Lexmark t630
Paper size is incorrectly set!.....
Merlin's idea, of what paper Lex has, and Lex's are different or you have loaded Lex's tray with the paper sideways
Your in Oz so it would be A4 standard and I guess your trying to print B5 script. Try these
The printer has been loaded with one size paper but thinks it is another. change printer settings via keypad on printer
The B5 scripts paper is being loaded sideways instead of length ways or visa verse
There is a incorrect setting in the printer driver that is set up for this specific printer that 'merlin' uses, check print driver setting (control panel,printers and fax, right click on lexmarkt642's icon, properties and check properties fully) in windows software that is running under merlin, also check merlin settings if any for this printer
Nov 20, 2007 | Lexmark T642 Laser Printer
Lexmark X1270 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
