Question about Vanguard International Infra Red - Medium Infra-Red Mid-Size Heater
2 0f the trhree tiles are not turning bright red.
  • Vanguard Master
  • 43,501 Answers
This heater is a three stage heater...how many tiles are burning is dependent on the setting of the thermostat... (the knob on the top) and the temperature in the room...
If the setting and the temperature are close then the heater will only burn one tile....if the temperature in the room starts to drop then another will light.... and if there is a wide difference then the three will light....
If you have a room that is warm already then you may not be able to get all three to light as the thermostat may not go that high...
If the room is cool and the other two tiles are not lighting then either the thermostat has gone bad or the gas valve is bad.... troubleshooting that is very difficult....it is best to replace the thermostat first and then if that does not work either replace the heater of the gas valve... however the gas valve will cost very nearly as much as a new heater...
heatman101
Posted on Nov 07, 2010
How do i get ceramic tiles to have a shine again. they are not high gloss but they used to have a shine to them
You might try a steam cleaner like the Shark Steam Cleaner. If you use a polish, sometimes that makes it worse and makes your tile dull. Just use plain old soap and water. The Shark also scrubs your floors as it cleans.
Feb 13, 2015 | Vacuums
Why is Samsung sch r970 battery draining fast?
Could be using too much live tile, background tasks, your display too bright... Also, turn off Bluetooth, and or wifi/cell network
Aug 31, 2014 | Cell Phones
Blade turns until you push against tile
You may have some burnt windings in your motor. If so, you'll have to replace the motor.
Apr 16, 2014 | Dewalt D24000S HeavyDuty 10inch Wet Tile...
Concrete tile or Clay tile
clay tiles have little more lifespan than that of concrete. While clay tile is only popular in its red color, concrete tiles are available in wide range of colors.
Clay tiles break easily but concretes do not. But both concrete and clay tiles are the pinnacles of beauty.
Dec 09, 2013 | Washing Machines
Screen very dark. Can see Icon and menu barely. A1285 was dropped on hard tile
did you try going into the settings and changing the brightness of the device?
Jun 30, 2011 | Apple iPod nano
I am not sure I can be any clearer than to say the saw dooes not cut the tile square.
the problem is probably the slide cart you set tile on to push it into the blade,on the right side theres a roller you can adjust the the height of the tray,or look at the very bottom of the cutting arm,left hand side,on the outside,where its painted red, theres 2 bolts that hold the cutting arm to the frame of the saw body,try this first, i bet nuts got loose and the cutting arm dropped a tiny bit screwing everything up
Dec 28, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
Red screen on 50" toshiba rear projection
red tub bad, you can adjust the red tub when you take the lower part of the front panel off and the plastic cover under the front screen
there will be 6 controls on the right hand side the three top are the brightness look for the one mark "R" and see if turning it down helps.
Dec 02, 2007 | Toshiba 50HX81 50" Rear Projection...
TV Codes
try
www.remotes.com
to solve your problem.
Oct 14, 2007 | Konka K2386U 23" TV
Vanguard International Infra Red - Medium Infra-Red Mid-Size Heater Logo
74 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
