Question about Sony KDF-E50A10 50 in. LCD HDTV
My TV screen went black and now the bottom light that is usually green, now blinks red 5 times in a row. Can you please tell me what is wrong w/ it?
My tv turns on for about a minute and it turns right back off. Can you help me?
Posted on Sep 18, 2012
  • 10,594 Answers
5 times red standby light blinking shows problem with ballast supply board in Sony KDF-E50A10 model tv, ballast supply board provides high voltage to lamp to produce high bright light.
Please check/ replace ballast supply board in tv by local tv repairman.
Thanks.
Posted on Nov 07, 2010
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
RED FLASHING LIGHT
sir
these are the causes for 5 red blink in your modal
Video OUT (IC1545) is
faulty. (A board)
• IC001 is faulty. (A board)
• Screen (G2) is improperly adjusted
thanks
Oct 03, 2017 | Sony Televison & Video
I have a Sony KF 50 WE 610 projection screen TV. It has worked perfectly since I bought it six or seven years ago. This morning I turned it on and the sound came on for a second, but then the sound went...
Hello
Five consicutive blinks at a time and the stops and again blinks five; is its self diagonosis procedure. All modern Sony sets has this function included in its circuits. If the system control IC inside it detect any fatal fault inside its circuits system, it will give a signal to its power control unit to shut it down its high voltage outputs to protect the other components from further damage. In your set; as Sony describes; I quotes:-
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Actually the components marked in numberes will not be the same as in your TV. But the fault will it be.
    If you have enough knoledge in electronics and have a concept of soldering and have a good quality multimeter; youreself can do this work by home. OK
    Mar 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
    SONY KDF-E55A20 5 red blinking lights on power button
    Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
    A1085447A* LAMP BLOCK ASSY XL-2200U
    It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
    Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
    May 18, 2009 | Sony KV-36FV26 TV
    Red light blinking three times in a row
    Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
    Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
    Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
    TV screen went black, sound ok, red light blink 5 times
    Be sure its blinking 5 times, count after it cycles the first time through the red lights. If it is fact 5 times, that is a lamp driver error.More likely it cycled 4 times, which is common on this model, if that's the case, then it's the fan. Most likely the large one in the rear...It's an easy fix, just pull the back off and replace the part.
    Sep 14, 2008 | Sony KDS-R50XBR1 50" HDTV
    Blinking power light.
    i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
    did you find a solution?
    Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
    PT-60LC13
    there are fans inside tv need to make sure they are clean and free of dust
    Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
    Bad lamp?
    If you have the owners manual look on page 64 and see what it says there about the light lighting up in the front of the unit. if you do not have the owners manual, you can get one for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/52-62HMX84_E_R1_093004.pdf
    Jun 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
    Sony KDF-E50A10 50 in. LCD HDTV Logo
    538 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
