Question about Gateway (4000274) Motherboard
Has anyone had a problem with the on board vgp (monitor port) on this gateway motherboard model? I have added a graphics card but my monitor still does not come on. I can't get into bios, of course, to see if it recognizes the new card. Thanks in advance for your kind consideration and rapid response.
    Genius:
  • 1,066 Answers
Try to reset your bios. here is posted a picture of the bios reset jumper-
<a rel='nofollow' href="http://support.gateway.com/s/MOTHERBD/ANIGMA/m00274/m0027426.shtml">clicky<a/>
to access bios, press f1 immediately at boot, at 1 second intervals. you need to change the graphix adapter from "integrated agp" to "agp" or "pci", depending on your card. this should be under, "boot options>initial display device".
since you prolly have to do this with the integrated video hooked up (since it will be set to "internal vga" until changed) you are prolly up a creek without a paddle.
Posted on Nov 07, 2010
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
Gateway with 2 data ports
The "Connect monitor to alternate video port" message suggests that it is the motherboard video port. Since your computer has a video graphics card, the motherboard connections are disabled in the BIOS. (This avoids conflicts.)
Many video cards have several display ports each of a different type (VGA, DVI, HDMI, DisplayPort (less likely on a low-end desktop)) . Some of these cards can drive two monitors at the same time. Look at where your current monitor is connected, then consider an adapter to connect the second monitor to that video card. (For example, a DVI to VGA adapter will let you connect a VGA monitor cable to the DVI port.) Some DVI ports will let you run two monitors from the one port with a splitter.
Gateway has support documents for their computers here: http://support.gateway.com/us/en/support/default.aspx . You'll need to use the model number and look for the User's Guide, Top Answers and support documents tabs.
The only way to use the blocked port would be to enable it in the BIOS (usually press F2 on start up for Gateways). Press this key repeatedly from power on until it responds. I frequently miss the timing, just shut down and try again. However, first you would need to remove the graphics card drivers (uninstall program (Catalyst for AMD/ATI) and the drivers) from your Windows OS. Then remove the graphics card from the desktop. Since this requires opening the computer, you will need to be careful to remain grounded relative to the computer. (Use a ground strap or work carefully touching a metal surface of the case.)
Please add a comment with your computer's model number and I'll be glad to give you specifics on running two monitors from your system.
I hope this helps.
Feb 21, 2012 | Gateway GT5694 Desktop Computer
Analog output cannot display video mode
Hi, there!
Please check the connection of DVI or VGA cable which connect between your computer box and monitor. Check at the back of your computer box, how many VGA ports(the blue port)? If your computer box have 2 VGA ports( one in-built on-board and one from added graphic card), always connect to the one from added graphic card, not the one on-board. Hope this help. Thanks for readin.
Jul 11, 2011 | Dell Monitors:Dell 1801FP Driver
Compaq Presario SR1750NX wouldnt come on, installed dynex 400 watt atx power supply now it comes on & fan runs but monitor is still blank. Installed ATI RADEON 7000 GRAPHICS CARD, still nothing, the...
After adding new graphics card monitor display will not work with motherboard display connector.
So, connect your monitor VGA cable with your graphics card display port.
Thanks for using FixYa.
May 22, 2011 | Computers & Internet
I was Looking at some of the other posts and was wondering if the BATERY CELL 2032 could be the problem to my VGP problem. What is currently happening is any card i plug into my VGP slot, is non responcive...
Changing the battery on the board won't make a difference. It is clear that your "VGP" slot is damaged as there is little chance that all 5 of your test cards are damaged. The onboard video controller functions independently of the "VGP" slot and should not be affected by its failure.
Before you ask, there is absolutely no way to replace the "VGP" slot on the motherboard. You must replace the entire motherboard. If you can find a board with the exact same northbridge and southbridge chipsets you might be able to avoid reinstalling your operating system.
Now, one more thing to clear up. There is no such thing as a VGP slot. You have either an AGP or PCI-E slot.
Please vote for my solution if it helps.
Sep 26, 2010 | ASUS K8S-MX Motherboard
Gateway monitor is black
Try to replace the display cable. If you have any graphics card connected on motherboard eject it out and try get video from on board display port.
For any other query and to thank me you can also Mail on my email Ejaz89@live.com
Aug 06, 2010 | Computers & Internet
Adding a video card and get no output
Look in the motherboards manual for info about installing graphics cards, see if it needs jumpers. Plus make sure you plugged the monitors vga or dvi on the right place (VGA or DVI port ON the graphics card, NOT on the old vga port you used to plug your monitor before )
See if it works otherwise tell me..
Sep 14, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Monitors wont work
It appears that you have a faulty graphics card.
If the graphics card is integrated with the motherboard then it cannot be repaired. Just purchase a new AGP graphics card, insert it into the AGP slot and connect your monitor to this card.
You may need to go to the BIOS setup to disable the on-board graphics card.
If you don't have an integrated graphics card, then buy a replacement graphics card.
You will need to install the new graphics drivers after installing the graphics card.
Nov 13, 2008 | Gateway 310 S PC Desktop
3 monitors on dell vostro 200
Go to your bios and check if your bios allow that. Usually if you connect a card on the motherboard slot automatically the on board card becomes unavailable.
If your bios doesn't allow to make changes you can add another pci video card or connect some vga split signal to get the image on 3, 4, or more monitors with a single device.
Oct 22, 2008 | Computers & Internet
Connecting monitor to gateway 400 vtx laptop
Hi Spratty,
You can fix this problem simply by pulling the computer out, then looking for a blue vertical port (if you don't have a graphics card) or a blue Horizontal port (if you do have a graphics card, which is usually located at the bottom of the computer.)
Count the pins on the cable then count the pins on the port.
The end of the monitor cable should be Male which are pins only and the port should be Female which are slots where the pins go.
Make sure that the sides of the cable matches the sides of the port (which is a upward angle)
If you have anymore problems please let me know,
-Daniel.
Nov 05, 2007 | Intel D845GVSR Motherboard
Gateway (4000274) Motherboard Logo
188 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
