Question about Broan-NuTone RL6100F Kitchen Hood
Air blow thru the light hole on my kitchen range hood model broan elite 550 cfm.
  • 744 Answers
SOURCE: I just had a Broan Elite E662 hood installed and
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Posted on Dec 18, 2009
  • 1606 Answers
SOURCE: Broan Allure range hood fan
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
Posted on May 19, 2011
  • 224 Answers
SOURCE: My Broan range hood keeps
This sounds like something has got into the track area and is setting off the safety. they are designed to stop raising or lowering if they meet any resistance and anything in the track area will cause it to happen in both directions
Posted on Jun 26, 2011
GodBlessU
  • 3513 Answers
SOURCE: All electronics in the Broan
Hi
Turn off the main switch and rcd and open the CU. A residual-current device (RCD) is an electrical wiring device that disconnects a circuit whenever it detects that the electric current is not balanced between the energized conductor and the return neutral conductor. Connect temporary wires (preferably some bright color you would not normally see in a CU so it can be easily removed later) between the earth bar and the neutral bars.
Check for continuity with a multimeter between the earth and neutral wires at the cooker hood feed position .If there is no continuity at this stage you have serious problems and should get a sparky in then disconnect the neutrals of each circuit from the CU neutral bar one at a time and retest continuity at the hood (start with the likely ones like kitchen sockets and downstairs lights and cooker circuit if present) .When you find out which circuit it is put its neutral back in the bar and start breaking that circuit in various places until you find where it's spurred from .
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 26, 2011
ekcnoel
  • 998 Answers
SOURCE: I have a Broan range
Sir try to check the starting capacitor and the ac supply feel free to send feed back good day and best regards.
Posted on Sep 13, 2011
Light button blinking why
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Jun 22, 2014 | Broan-NuTone Broan Elite E661...
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
Lights on hood fan will not shut off.
It sounds like your switch is getting stuck internally. It most likely needs to be replaced.
Here is a break down of your unit. http://parts.broan-nutone.com/broan/Shop?DSP=30200&PCR=1:1000&IID=QS330AA&imagesequence=
Also, you can order parts directly from Broan, here. http://parts.broan-nutone.com/broan/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=QS330AA
Hope this helps you somewhat, please post back if you need more help.
Mar 07, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
In winter, cold air blows back down and out through the fan.
Either a backdraft damper was never installed in the ductwork or the damper is stuck open...
Has it always been this way?? If so then the damper probably was never installed and you will need to have one installed to stop the air...
If it was good at the beginning and now is not then the damper is stuck open...you will need to find it and then get it working agian...
The dampers often are right at the outlet of the hood...if you take down the hood it should be right there...
heatman101
Feb 11, 2011 | Broan-NuTone Best By Broan EB12 External...
Broan elite hood vent has blinking light that won't reset with power off/on. What gives?
I turned both the light and fan on then pushed the filter button. After a loud beep the filter light reset went off. This worked for me.
Jan 21, 2011 | Broan-NuTone Broan Elite E661...
Fan blows air down instead of pulling up
Sounds like the motor is wired backwards. You'd probably want to get an electrician in to take the motor out and rewire it.
Jan 01, 2011 | Broan-NuTone Allure QS130SS Kitchen Hood
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
Fan turns on and off since turning hood light on a few days ago
If it is a Broan, there is a delay button that was also depressed. It will turn the fans off after a few minutes. If not, then you're shorted out either in the control panel or the wiring in the range hood.
Sep 23, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Air blows thru the Front of the fixture
on theese if your going to vent them out the top you have to turn the fan housing so the front is vent is blocked if i remember right
Jan 10, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone RL6100F Kitchen Hood Logo
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
