Question about Black & Decker 50 Watt Electromate with Radio and Lantern #PS50LRB
I've been charging this thing for 3 days and it will not turn on. When I pull the batter out, it shows it is full. When I insert it, it shows it is dead. Nothing will work on the latern/radio.
Turbo won't work
emission control tank full, will make it act like that. have it checked out. good luck
Jul 18, 2013 | 2002 Renault Megane
My john deere la125 seems to be drawing power wile shut down, it take a week for the batter to go dead, i've pulled the batterer and it stays charged up , I've checked the charging unit and i
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
Doc
Nov 23, 2012 | Garden
Cub cadet model 1520 won't start.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Jun 09, 2012 | Cub Cadet Garden
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Dec 27, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Batter keep going dead
Check you charging system, with a volt meter is should show between 13.5-14-5vdc at the battery with the engine at 2000 RPM. Test your battery for load capacity and dead or weak cells...1 dead cell will drain the others. Hope this helps.
Jul 13, 2011 | 2004 Yamaha YZF-R1
Iphone is dead
Almost same problem here.
It worked perfectly yesterday and this morning, showing almost full battery. Suddenly, in my pocket, it died.
This is not the first time it does that, actually 3 days ago it did the same thing. I charged it up, connected it to iTunes 9 and restored it to OS 3.1 (from jailbreaked OS 3.0.1). Then it worked!
But the funny thing is that it showed battery power was about 75%, then it blacked out.
Also charging the battery gives me a hard time - like it just won't do it.
I suspect the battery to be dead, so I'm gonna try to pull it out - wait 30 seconds - then plug it back in. Anyhow, I'm going to buy a new battery anyway. Suggest you try the same thing, at less you've still have warranty on the phone (I don't).
Sep 13, 2009 | Apple iPhone 3G
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Battery shows a full charge but wheels won't turn while grounded
theres nly 2 things at work here in my opinion, the battery and the charger, if this bike is of any age chances are the battery is no longer good, it may read ok with the meter but when you put it under a oad like trying to ride it it may go to 0000 see if you can mete it under aload
Mar 14, 2009 | Razor MX500 Dirt Rocket
It´s dead
hey buddy just do one thing.. open the metal cover removing the 4 philips screws.. and then remove the battery then reinsert the battery and try.. it should work ... i had the same thing few days back.. it was charged and in my pocket when i tried to listen to it the damm thing wont switch on .. so i removed the batter and put a LED to the terminal to check power and inserted it back it and valaaa it hot and running again..
Jan 25, 2008 | SanDisk Sansa e250 MP3 Player
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Black & Decker 50 Watt Electromate with Radio and Lantern #PS50LRB Logo
51 people viewed this question
Top Black & Decker Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black & Decker Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
