Question about Reddy R155D Utility Heater
Were do you check for a filter? Heater is letting out fume.
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Nov 07, 2010
Reddy heater 170T- terrible fumes-fuel pressure problem
Are you sure there is not water in the tank? Fuel pressure should almost never need adjusted.
Jan 08, 2014 | Reddy Heating & Cooling
When heater starts up it puffs fumes then lites
Generally, if the heater puffs fumes at start up it is because there is not instantaneous combustion.
What causes this?
  1. Worn nozzle
  2. Incorrect (click for instructions) air pump pressure
  3. Spark plug carboned
  4. fuel filter restricted
  5. Air leak or vac leak between the pump and the nozzle
Generally speaking, if the fuel is being delivered as a FOG not a SPRAY, and the spark is strong and properly oriented there will be immediate combustion at start-up.
Nov 14, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy heater R100B gives of fumes when i use it
Not familiar with the R100B unit. Is it kerosene, propane or something else. Anytime a combustible heater gives off fumes it is not burning the fuel completely. This could be clogged filters, wrong fuel ratio or something else. Send me more info and I will try to solve your problem.
hardrocko
Jan 31, 2010 | Reddy Heating & Cooling
WE HAVE A HEATER THAT HAS STRONG FUMES WHEN RUNNING. THE COILED FOAM FILTER IN THE BACK FELL APART. DOES THIS HAVE ANYTHING TO DO WITH IT?
It sounds like you need to increase the air mixture. there is an adjustment screw in the back next to the foam filter (which you can get a new one at Ace Hardware). Dial the screw in 1/4 turn at a time until the nose cone turns about 90% red/orange and you should notice a great reduction in the fumes and a greater heat output.
Jan 07, 2010 | Reddy R70ET Utility Heater
Anti freeze smell when car is shut down
do u smell coolant in the car when te doors are closed? if not it is not the heater core, have you had the system pressure tested at a shop? If I had to guess the 2 area's that would cause this are loose radiator hose clamps that just seep, not enough to get to the ground, but enough to smell the coolant, the other a slight leak at the water pump weep hole on the underside of the water pump, this can also be a seep and not reach the ground. Try adding a can of Alumiseal radiator and block sealer, comes in a little aluminum colored tube, about $3 US
Mar 05, 2009 | 2000 Buick LeSabre
Smell of oil in car when heater is turned on
The oil smell may be trapped in the car's cabin air filter.  Locate it and replace it.  Then on a dry day, spray A/C deoderizer (Fridge Fresh) in the cowl area with the heater blowing on high and all four windows open. Repeat a few times in an hour or so, then let it air out well.
Jan 17, 2009 | 2001 Volkswagen Passat
Exhaust fumes in car when heater is running and car is at a stop.
Hi, What you have is a leak in the exhaust system. What you need to is take the vehicle to a repir shop (anyone that can weld) Drive the car up a ramp, and start it, you will see the fumes emitting from the hole in the exhaust and entering the heater ventilation system(thats how its getting in the car) simply weld the leak shut. Ps It can also be the exhaust manifold gasket that needs replacing, check for a leak first.
Dec 16, 2008 | 2002 Subaru Legacy
Fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Dec 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fuel Smell in Car
I had this problem.  The fuel pressure regulator was leaking gas.  $50-$100 for a replacement.  It is not safe to drive around if you have a gas leak - could start a fire. Look under the hood to find where the gas is leaking, should be easy to see/smell when the car is running.  If you cannot find it, take it in to a shop right away.
Oct 16, 2008 | 1996 Dodge Intrepid
Reddy R155D Utility Heater Logo
56 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
