Question about Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder
Incompatible TV Setting
When I try to play some DVDs I get a message saying Incompatiable TV setting. I can't find any reason for it. Anybody ever seen this?
The solution to your problem can be found here:
http://www.avforums.com/forums/showthread.php?t=491865
Posted on Jun 23, 2008
Says all DVD discs are "incompatible" how to fix
Unless there is a malfunction of the device, the only reason for all DVDs to come up as incompatible might be if the DVD's region codes do do match the code set into the player.
Nov 06, 2015 | Televison & Video
Dvd troble
ur dvd can play all-regions ?
chk region setting of the dvd
Jun 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Copying DVD to HDD
What kind of dvds are you trying to copy? If you're trying to copy movies from the store then it will never work and there is a security protocol the blocks that.
Mar 12, 2014 | Panasonic DMR-EX773EBK DVD Recorder
Error: incompatible TV settings
You need to pull out the manual. The settings are related to the INPUT to the TV. You must select the DVD-CD settings from the Menu and switch from the TV setting to DVD.
Feb 26, 2014 | Sharp Televison & Video
Iview 2600hd dvd player has error "this player is incompatible with the region marking of this disc"
DVDs are coded for different areas of the world. If you bought the DVD from an online source it may not play on your format of DVD player.
Jan 24, 2013 | Iview 2600HD 5.1-CH Digital HDMI...
When I connect my Laptop to my HD TV using a HDMI cable, I get a message saying "incompatible video signal has been received.Check the output video settings." Any ideas?
A TV will only display certain resolutions from a pc I would try to lower your pc resolution to its lowest setting and see if that clears of the problem if it does then slowly increase the setting until you get that message again then dial back one setting and that will be the highest resolution it will take. Also be aware that if you are trying to play certain games on your pc while displaying on your HDTV that signal will not always render.
Apr 10, 2011 | Computers & Internet
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
DVDs will not play at all!
You need to change the motor disc spindle
Jul 04, 2009 | Televison & Video
Multi region code for DVD
You need to hack the dvd reinstalled firmware, I can see if I find hacked firmware for your dvd
May 01, 2008 | Onkyo DV-CP704 DVD Player
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder Logo
397 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
