Question about Whirlpool ED2FHSS Side by Side Refrigerator
Whirlpool Side by Side Refridgerator
The unit is freezing and keeping things cold, no leaking etc. BUT we are noticing that the rubber gasket around the door is extremely hot to the touch and so is the middle door strip between the two doors. I mean hot where it could burn a child touching it. Any idea what would cause this?
  • Anonymous Jun 30, 2008
    We just bought the fridge and installed it yesterday. It is working fine, ice and water, keeping things cold etc, but we noticed that the frame around the freezer is hot to the touch. Wondering what could be causing this.
  • 77 Answers
The heater in the gasket area is on when the unit is cooling (compressor running). hot weather makes unit run more, hence the heater is on longer and gets warmer. Coils under the unit being dirty or many door openings can also cause extra run time.
J
Posted on Jun 15, 2008
  • 828 Answers
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
I have a Jacuzzi Cirrus, bought in 1996. It leaks slowly (I have to fill every 2-3 days. It drops about 8 inches and gets close to below skimmer. Do you know what could be leaking?
Each of the jets have rubber gaskets. The continual heat and cemicals starts to deterioate these and the tub leaks around the jets. This is not always noticeable do to the fact that the water is hot and tends to evaporate. But even a small leak multiplied by all the jets adds up. 1996 is a long time and the replacement of these gaskets are overdue. I hope this has helped it would be the first thing I would look at given the age. Hope this has helped good luck and have a great day. Jeff
Mar 29, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
ED2KVEXVL Whirlpool refridgerator - not cooling in refridgerator
Your freezer is not reaching the target temperature to produce ice - obviously your whole unit is not cooling properly - first thing to do is shut it off unplug it and remove the back panel from the freezer and look for ice buildup and overfrost on the evaporator - this is a classic symptom and will cause cooling problems - manually, using a hair dryer, melt the ice and frost from the evap until everything is cleared up and drips into the drain down the drip pan - once everything is cleared up put back the panel and turn everything on - allow a couple of hours for things to cool up - if it cools normally, then your problem relates to a faulty defrost system in which case you would need to have it serviced and replace one of the defrost timer components (control board, element, etc.)
Set one of these special refrigerator thermostats (not the mercury ones, but I use the round gauges) put one in freezer one in refrigerator and after couple of hours monitor the temps. Freezer should not be warmer than 10F - normally 0F, but optimal temps are -10F (and also if you want hard icecream) -10F allows faster recovery in case of outages. For refrigerator no warmer than 40F - you want optimal to be 34F.
You want to also make sure your evaporator fan motor is spinning and look for any door gasket leaks.
If, after checking your evaporator fan and coils for frost, and door gaskets and you notice your unit is not cooling properly and your compressor is running continuously without cycling off, then next step would be to check the condenser and clean the excess dust (which traps the heat) if your condensers are at the bottom and they are clean, then make sure the condenser fan at the back / bottom of your unit is running.
If all fails, then the last thing (rare) would be a sealed system leak, in which case you will need to get it serviced and it will cost you a lot of money.
If you notice your compressor cycling off before the target cooling temps, then raise your cooing knob at higher temps, if it works then your thermostat is out of calirbation.
If everything cools normally after you've defrosted manually then the problem relates to a defrost problem - in which case you will need to get it serviced and have the control board checked and defrost timer components.
If your freezer is cooling normally and not your refrigerator section, then check for any obstruction of the vents, door gaskets and if you have one, the damper flap not opening wide enough or at all to let cool air in, if applicable to your model.
best of luck.
Sep 20, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
My refridgerator is not keeping cold any more? what is the problem? The model is Ge GSS22WG. it does not freeze or keep things cold, all of my food went bad. I need help I dont have the money to buy a new...
it could be an air flow problem. Pull the unit out, unplug it. Clean out any dust, dirt, or anything else you see in there. Also when you push it back in make sure you have a few inches clearance behind and to each side of unit . Good Luck.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile not keeping items cold or frozen
Does'nt sound like your compressor.sounds like you may have frost build up,and the tubes may be partially blocked.Try defrosting the whole unit.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 21, 2009 | Refrigerators
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridgerator side of my refridgerator keeps freezing my food
The problem may be low gas or it may be the thermostat is set too low.  First, look at the possibility that you may have the food partly blocking an air channel which is where the very cold air is coming from..  Fridge side should read about 40 F after the door is closed for about an hour.  If colder, adjust.
Nov 15, 2008 | Refrigerators
GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
Whirlpool ED2FHSS Side by Side Refrigerator Logo
756 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
