Question about Nintendo 64 Console
My brother acciedently pulled out a game out of my n64, he quickly turned it off, put another game in, then turned it back on, but it wouldnt turn on. It's plugs have been check, we've dusted it, what happened to my N64, and how can I fix it?
    President:
  • 894 Answers
Well if you don't turn off the power when removing or putting in a gamepack it will ruin the console
then.
Posted on Jul 20, 2011
Goldeneye deleted all it's memory randomly
Hello, n64 cartridges are outdated for that reason exactly. They have a small space to save game info. A quick off and back on is actually the way you reset the memory. Say you bought someone else's n64 and each game you loaded had saved info on it. Powering off and then turning it back on, would erase that data and allow you to start your own game. Once your 64 went instantly off, it reset/erased the saved info. Unfortunately there is nothing I know of to get it back. Sorry. Hope this helps though.
Nov 18, 2011 | Nintendo 64 Console
I dont know how to set it up
- First you need a rather old TV, like maybe before 2002, if you have one. Because on newer TVs N64 graphics are terrible !
- Once you have your TV, check to see if you have two cables with your 64 (if you don't something is missing !). One shaped like a little box on one end and an electrical plug on the other : you hook up the little box to your N64 and plug the device in the nearest power socket. The other cable has a a strange black and rectangular input that hook up in your N64 and 3 sockets that are red, yellow and white. Connect the latter on your TV by finding the same sockets with the same colours !
- Connect your controller to the console (it's the round-ish sockets in front of it)
- insert your game
- THEN turn on your console. Don't turn it on unless everything hooked up !
(if it doesn't work you may want to try the famous turn-off-the-console-blow-into-the-cartridge-put-it-back-and-try-turning-your-N64-again trick !)
Good luck ! :)
May 28, 2011 | Nintendo 64 Console
How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack ' eHow.com http://www.ehow.com/how_6566153_erase-pages-n64-controller-pack.html#ixzz15ZouU9Pe
    Nov 17, 2010 | Nintendo 64 Console
    When i put this one game only in my n64 console,
    You could try giving the contacts on the cartridge a clean with a cotton bud and non-solvent cleaner
    Aug 17, 2009 | Nintendo 64 Console
    GOD GARNED N64 GAMESHARK!
    The original GameShark for the N64 only works on certain games. During the N64 era, game creators would often include code on the game itself that prevented the use of a GameShark. It is possible that you can find a newer version of the GameShark that would work with this so called "blocked" games, but it might be difficult.
    I'm assuming that this is the GameShark Pro for the N64. If so, the button is used to find and create your own cheats, such as infinite life, infinite ammo, etc...
    To use this feature, start the game, say a first person shooter, and load into a level and when you are ready to begin playing, press the button. The GameShark screen will show up and you can say "search for code" or "search for changes" something like that and the game shark will run a diagnostic that it shows on the screen. A number will appear noting the number of lines of code executed since the game loaded. When it is finished, press the button again and it will return you to the game exactly as you left it. If you are trying to get infinite ammo, simply shoot once and press the gameshark button again to search for codes again. When it is finished, the number it shows will be much smaller, since much less lines of code have executed since the last run. Press the gameshark button again to return to the game and continue the process until you have only a few, say 5 or less, or even just one code left on the gameshark diagnostic. This code will be the one that dictates the amount of ammo that you have. By altering this code with the gameshark, you can either start with an extremely high amount of ammo, or have infinite ammo entirely. The key to this strategy is to do as little as possible between code searches so that you can quickly narrow down on the code that you trying to alter. Hope this helps.
    Aug 05, 2009 | Nintendo Video Game Consoles & Games
    How does it work?
    put in oe of the working games and go to keycodes hit the A button and you can scroll through a list of games that need keycodes. Select the game and then turn your N64 off and then put the game you selected in the gameshark and turn it back on, it should now work
    Mar 23, 2009 | Nintendo GameShark Pro for 64
    Nintendo 64 Console Logo
    91 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    phil
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
