Question about Yamata FY900 Mechanical Sewing Machine
Brother PR600 embroidery machine, the needle threader is stuck in the out position with a vipor error. How do I get the needle treader retracted?
  • judelumala
    judelumala Oct 17, 2012
    I have the same problem with my PR600.
    Problem Solver:
  • 28 Answers
Hi usually when an auto threader jams in the out position the problem is the small hook that passes through the eye of the needle is getting caught in the needle. Use a magnifying glass to check if the small hook is caught in the needle eye or jammed on the side of the needle. With the power off and disconnected you should be able to unhook it and manually push the threader back then Check the needle is the right one and fitted correctly, check the threader by slowly bringing the threader by hand to just behind the needle it should be lined up to pass through the eye without touching it if the small hook is bent or damaged it needs to be replaced and adjusted
Posted on Oct 06, 2014
Hook out of date
Posted on Jan 21, 2011
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
How to get brother pr600 out of main motor test mode?
Looks like the machine is bound up, or the motor is failing. If the hand wheel is easy to turn then it is probably the motor drawing too much current.
Brother recommends a new motor and belt every 1500 hours of run time.
Feb 25, 2015 | Brother Sewing Machines
The needle threader on my embroidery machine is no longer working.
There's a possibility of it being related. I would need more information though.
Jan 26, 2014 | Brother SE-270D Computerized Sewing...
I have a pr600 brother embroidery machine,it trims the thread too short
Make sure that when your machine stops and cuts that your needle is in the upper most position. Other than that you may need an adjustment from a pro repairman.
Dec 04, 2012 | Sewing Machines
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Feb 12, 2009 | Janome Memory Craft 9000 Computerized...
How to use automatic threader on the pe180d embroidery machine
make sure needle is in the highest position before you thread
mary h
Jan 06, 2009 | Brother Disney PE-180D Computerized Sewing...
Brother PR600 embroidery machine has decided it won't thread any longer, had a wiper error which I cleared but the machine now won't thread the needles?
Just got the pr600 machine. Can't get the upper and lower thread to connect. Keep getting the error message to check upper and lower thread.
Jun 11, 2008 | Husqvarna Designer I
Yamata FY900 Mechanical Sewing Machine Logo
347 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Michael Kovalik III
Michael Kovalik III
Cleverer2
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
