Question about HP Photosmart C6180 All-In-One InkJet Printer
Ink system has failed - HP Photosmart C6180 All-In-One InkJet Printer
    Guru:
  • 731 Answers
Solution One: Reset the printer
The error message might disappear after you turn off the printer and then turn it on again. After you make any adjustments to the cartridges or the print head, reset the printer in order for the error message to clear completely. Follow these steps to reset the printer.
1.Press the Power button to turn on the product.
2.With the product turned on, disconnect the power cord from the rear of the product.
3.Unplug the power cord from the wall outlet.
4.Wait at least 15 seconds.
5.Plug the power cord back into the wall outlet.
6.Reconnect the power cord to the rear of the product.
7.If the product does not turn on by itself, press the Power button to turn it.
Solution two: Remove, clean, and reinstall the printhead
If the previous solutions did not resolve the problem, the printhead might be installed incorrectly, or there might be ink or debris on the printhead electrical contacts. Follow these steps to check and clean the printhead.
Step one: Remove the printhead
2.Open the cartridge access door.
3.To remove each cartridge, press the tab on the front of the cartridge to release it and remove it from the slot.
4.Lift the latch handle on the carriage until it stops.
5.Lift the printhead straight up to removes it.
Step two: Clean the printhead
There are three areas of the printhead that need to be cleaned: the plastic ramps on both sides of the ink nozzles, the edge between the ink nozzles and the electrical contacts, and the electrical contacts. Follow these steps to clean the printhead.
Gather the following cleaning materials:
  • Several clean, lint-free cloths or papers. Coffee filters and glass-cleaning cloths work well.
  • Distilled or bottled water. Do not use tap water, because it can contain contaminants that can damage the printhead.
2.Lightly dampen a clean, lint-free cloth.
3.Use the damp cloth to wipe the electrical contacts from the bottom to the top. Do not go past the edge between the electrical contacts and the ink nozzles. Repeat this motion until no ink remains on the electrical contacts.
4.Use a fresh, lightly dampened, lint-free cloth to wipe any accumulated ink and debris from the edge between the ink nozzles and the electrical contacts.
5.Use a fresh, lightly dampened, lint-free cloth to wipe the plastic ramps on both sides of the ink nozzles. Wipe away from the nozzles only.
6.Dry the previously cleaned areas with a clean, dry, lint-free cloth before proceeding to the next step.
7.Lightly dampen a fresh, clean, lint-free cloth with bottled or distilled water.
8.Clean the electrical contacts inside the product by wiping them from top to bottom. Repeat this motion until no ink remains on the electrical contacts.
9.Dry the area with a clean, dry, lint-free cloth.
10.Reinstall the printheads
Please let me know after trying these steps.
Posted on Nov 07, 2010
Why is the plotter ink leaking
Depends on where the ink is leaking. Could be a failed seal on the ink pressure system, or a leak where the cartridge mounts into the printer. If the ink is everywhere, then likely part of the pressure system has failed. If it is just dripping then suspect a faulty cartridge or printhead.
Jan 18, 2015 | Canon imagePROGRAF iPF610 - large-format -...
HP Photosmart D7360 ink system has failed. How do I fix this?
with 2 new cartridges installed, shut the machine off and back on again.
Jan 06, 2015 | HP Photosmart D7360 Digital Photo Inkjet...
Ink system has failed. Unable to copy, receive
normally in this scenario the whole printer needs to be replaced..
Oct 22, 2009 | HP Photosmart 3310 Printer
Won't print
Ink system has failed. Unable to print. Refer to printer documentation. Error:Oxc18a0101
Mar 29, 2009 | HP Office Equipment & Supplies
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
Ink System has failed
Since you have not provided the manufacturer of your printer, I assume you have a HP printer. This Error message occur mostly on HP printers.
Try this solution. I hope it helps you.
ink system has failed. unable to print
Jul 12, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
23 people viewed this question
Clive
Clive
