Question about NRS Bilz Box
I have a bilz obsticle box that the ball is stuck in the box...I don't have instructions and it is in a corner square that has no escape....is there a way to trip the box and pop it open to release the ball?
When getting up internet explorer page on my asks pc, it will only appear as a tiny page in top left corner. I am running Windows 8.1
on the tiny page at the right hand top corner is three symbols - {squares} and a white cross x in a red box.
Move the mouse pointer over the square boxes and click the left mouse button this should maximise the window.
Feb 24, 2018 | Internet Computers & Internet
Tip
Novalis - misshapen, mismeasured, debris on back of tile, broken edges, stuck to...
This is one flaw of MANY manufacturer's boo boos that I dealt with, and I am less than pleased given the price I paid for this Novalis flooring. They will be receiving a letter, as I have already written the major box store, Lowes.
I was excited when I opened the boxes, already had my chalk lines down, assistance with me, and began laying the tiles out in the correct direction. My mother, my assistance, began peeling the backs, and lying the tile into the lines. The first half of the box went smoothly, until it didn't. The tiles began to vary in size & shape, my mother mentioned it in a concerned tone. I looked through the rest of that box to find broken corners & more variance of sizes and shapes. Given I live an hour from Lowes, I called to ask if they had any more of the tiles I had, they did not have any, nor could they get any.
Being we were in the midst of the install coupled with being an uncontrolled Epileptic who cannot drive meant we were stuck with what we had. So, we decided to go ahead and open the other seven boxes of tile to see if it were just a fluke; it was NOT a fluke. So, we picked and chose the best tiles possible from the seven boxes. We then installed those tiles in the center of the room, leaving the jacked up tiles for cuts and along the walls where they would hopefully draw less attention. Sadly, we did NOT have enough tiles to complete the center of the room, given there were THAT many tiles with foibles which were not able to be ignored. We finished the install, while we managed the installation process without issue, the tiles are ANYTHING but up to par.
There are so very many problems with this entire ordeal in installing these tiles. I don't like the fact that I bought this with my "nest egg" money, I scrimped & saved specifically for this remodel. Only to open the tiles I paid so much to purchase, to find they were absolutely screw-balled with foibles. The tiles were NOT square aka misshapen & mis-measured tiles, beneath the paper debris was stuck to the glue on the back of the tiles, broken edges that were still inside the unopened boxes that were heavily padded, and some tiles were even glued to one another, when carefully separated you learned that one was broken. How this tile in the attached photo ended up getting wood embedded in it's front, I have no idea?
I am UNHAPPY. I would rather have purchased American, paid more for them, and cut corners somewhere else in my remodel insuring my floor looked perfect! We worked too hard to have it turn out as it did. Live & Learn!
on Nov 21, 2013 | Novalis Bella Tiles 18 x 18 Bella Napoli...
Dryer ball stuck-disapeared
Seems unlikely for the ball to escape, so be sure it is in there. Perhaps you can tilt the dryer up in front and support on blocks while you look under for it and look for the hidden fasteners which may be spring clips holding the cover!
Nov 29, 2013 | Frigidaire FRQG7000LW Dryer
Where is the fuel pump driver module on a 2008 Ford Escape
on the bottom of the car near the gas tank, looks like a small square box with wires connected to it.
Jul 22, 2012 | 2008 Ford Escape
GEARS NOT SHIFTING PROPERLY
Jul 10, 2012 | 1998 Ford Windstar
Ford escape location of set factory code for entry code on door
on my 2010 ford escape XLT i found the keyless entry code printed on a label on the smart junction box which is inside the center console. To get to the smart junction box follow these instructions.
1. with a non-marring tool(i used a putty knike wrapped in plastic wrap), pry up the chrome trim piece around the shifter.
2. Remove the storage tray from underneath the center console armrest and leave the armrest cover open.
3. Grab the center console finish panel near the cupholders and pull straight up.
4. Pull the finish panel up and back then set it aside.
5. The smart junction box is to the right and slightly ahead of the gear shifter. There should be a label with a bar code that says FoMoCo. In the corner of this label is a 5 digit number. This is the factory code.
Hope this helps.
Apr 01, 2012 | 2010 Ford Escape
Solution to bilz box
bilz box ,what make of car is this please
Dec 17, 2011 | Cars & Trucks
How do i use the square root button? I don't know how to use the gray symbols above the buttons.
Press the "2ND" key at the upper-left-hand corner of the keyboard to access the second functions. For example, to calculate the square root of 2, press 2ND [square-root] 2 ENTER.
Aug 26, 2011 | Texas Instruments TI-84 Plus Calculator
Can't get puzzle 100 make 7 boxes stuck for months help
This continues to be the most commonly asked about Curious Village puzzle on FixYa and a quick search would've found several pages of answers for this
As the hints state, all but one square is tilted and each pin can only be used once
The hints also give you the location of three squares and tell you the size and angle of another two squares
As an extra hint, none of the three small tilted squares mentioned in the hints overlap each other (knowing this gives you the location of one more square and just two possible locations for another)
From here, the rest should be easy (with eight pins to form two squares)
Make sure to use all the pins (all squares must have a pin in each corner)
A picture of the solution can be seen here if you need it
http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle100.html
Sep 29, 2010 | Nintendo Professor Layton & the Curious...
Assembly instructions for Niagara corner shower encloser
Go to this link and print the pages. original instructions. Good luck.
Feb 21, 2009 | Home
NRS Bilz Box Logo
123 people viewed this question
Top NRS Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a NRS Toy Expert? Answer questions, earn points and help others
