Loglk lcd tv fuse blow renewed the fuse but still on power two it
  • 10,594 Answers
If fuse blow again in power supply that indicates that power supply is defective and need to be replaced power supply board.
Please replace power supply board to fix your tv problem.
Let me know if you have additional question.
Thanks.
Posted on Nov 07, 2010
Fix tv blowing fuses
when replacing fuses in a device....if, when you next apply power to the device and it immediately blows the fuse again : Do NOT put in anymore fuses. It is time to visit a TV repair shop.
Oct 30, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
We had a trasnformer blow and our power went of.the tv didnt make no noise our nothing.when the power came back on the tv wont come on.
It sounds like you might get lucky and have blown the in-line fuse. By lucky, I mean, it could be worse, but you need to open the tv and check for the "white/Slow Blow" fuse that connects to the power plug of the tv.
Hope this helps :)
Mar 04, 2011 | Proscan 32LA25Q 32 in. LCD TV
I lost power in my house. I cannot get the TV to power up. Is there a reset button? what do I have to do to get power on the TV? All the other components linked to the TV are working.
Now,there is no power to the tv at all?Yes.Tries tv unplug,replug it back like about and hour later.That the resetting tv back to the factory setting.The tv now should be working again.If tv still have the same result,tv power supply board have problems,that the board,where the power a/c cord plug into it.Check the tv power supply board fuse,because u lost main power to the house.If u lucky,the tv power supply board only have a dead fuse,fuse is near where the power a/c plug,plug into tv to get it power.Fuse can buy it anywhere like Radio Shack like $1.50.After u repalced the fuse,if tv still getting the same result,than sorry ur whole power supply board have problems and it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 23, 2011 | Samsung LN52A850 52 in. LCD HDTV
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
Proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
Blows fuse internally when tv powered up
There is a short in it somewhere. check the ground.
May 24, 2009 | Olevia 237T 37 in. LCD TV
Blow fuse
If the TV keeps blowing fuses, there most be a short somewhere. Most likely the power supply board itself somewhere. But take it to a repair shop to find out for sure. The sad part maybe that you'll have to pay over $100 for someone to look at it.
Feb 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
42" LCD HD TV keeps blowing fuses.
A ceramic fuse stands up to heat better than a non-ceramic fuse. I'm no pro, but it sounds like your power inverter board maybe bad. There are replacements out there. Good luck
Jan 18, 2009 | Vizio L32 32 in. LCD HDTV
Tv keeps blowing fuses when its plugged in...
There should not be any reason for the new TV to blow a 15 amps fuse in the house.
The TV has an internal short circuit even if it is new, I would suggest to return it and get another one.
Good Luck.
Jan 06, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
