Question about Ovens
New electric oven won't fit flush against wall b/c the back oven panel doesn't align with electrical outlet. If back panel is removed (exposing wires) it fits perfectly. Is this a fire hazzard?
Master_Tech
  • 770 Answers
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
Please post the Model # from the units tag and i will see what I can do for you
Posted on Jan 26, 2008
  • 184 Answers
SOURCE: Wall Oven does not fit flush into built in cabinet
I HAVE SEEN SOME CABINET MAKERS BUILD A TRIM PIECE THAT GOES ALL THE WAY AROUND THE EXISTING HOLE THAT HAS AN OUTSIDE DIMENSION LARGER THAN THE CABINET HOLE AND AN INSIDE DIMENSION TO FIT THE REQUIREMENTS OF THE OVEN. IT ATTACHES TO THE FACE OF THE CABINET AND STAINED TO MATCH THE CABINET FINISH.
Posted on Apr 10, 2008
  • 161 Answers
SOURCE: zanussi electric oven.
The problem is usually a contactor or relay. The thermostat usually doesn't directly control the elements. Follow the wiring diagram or look at the wires from the thermostat. they usually go to a small box and then to the elements The contacts may sometimes stick or always stick. This part is a lot cheaper than the thermostat. Another problem is a burned out element. (Usually the bake element) This can short to ground and not let it turn off. When the elements are on they should glow evenly all over with no hot spots. Look at the broil element also. It is usually at least part way on during baking.
Posted on Jun 29, 2008
tborn6
  • 700 Answers
SOURCE: Replacing thermocouple on smeg oven
Look at the bottom of the oven and see if you can remove the panel, if its all one piece then take out broiler pan and look inside to see if you acan get to the pilot burner. Good Luck
Posted on Jan 11, 2009
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
I just replaced two of the capacitors and it worked thank God. I couldn't get at the 3rd capacitor with the soldering iron because the display blocks it and I couldn't see how to remove the display unit. We had already begun shopping for a new double oven. This was the last resort. The capacitors were $1.78 apiece at an electronics store. A repairmen quoted us a $780 fix - with him shipping the parts out to be rebuilt because Thermador is out of business and not producing parts anymore. There is a great place in Canada called Appliancetimers.com which will rebuild the timer for you inexpensively ($109) but they also want you to send the Power Relay Board which requires removal of the double oven to get at it. We found that it was much too heavy to consider that solution.
Posted on Mar 27, 2009
Kenmore digital oven model 79095321303 temperature is wrong. Digital display on oven says 350 degrees but oven thermometer placed in center of oven (middle rack) shows 200 degrees. When I up the...
It could be one of two things either the control board or the temperature probe and I suspect the probe and that is a do it yourself job.
The oven temperature sensor on your Kenmore range is a one-piece unit that mounts to the rear oven wall with a mounting plate. The sensor is not difficult to change. You will need to dismantle the rear panel from the oven to access the mounting plate. Most appliance repair shops will have replacement sensors. It is a good idea to take the old sensor with you along with the model number of your oven. This way you will be sure to get the correct replacement sensor for your oven.
  • Unplug the Kenmore oven power cord from the wall outlet. Move the oven range away from the wall so that you can access the back of the unit. (Ask a friend to assist you to move the oven. if necessary.) The oven may use an anti-tip bracket on one of the rear legs. Push the oven toward the back wall to release the leg from the bracket in the floor. Tilt the back of the oven toward you, and pull the oven forward.
  • Remove the screws that secure the back panel to the oven with a Phillips-head screwdriver. Pull the back panel away from the unit and set the panel out of the work area.
  • 3
    Locate the mounting plate for the oven temperature sensor on the upper right side of the back of the oven. There will be a single wire coming from the back of the mounting plate and the wire mounts to a clip.
  • 4
    Follow the wire to the connector on the other end. Pull the connector on the wire to disconnect the wire from the wiring harness.
  • 5
    Remove the two screws that secure the mounting plate to the rear of the oven with a Phillips-head screwdriver. Pull the temperature sensor straight out of the oven. Unclip the sensor wire from the mounting clip.
  • 6
    Take the oven temperature sensor to an appliance repair facility to purchase a replacement. Insert the sensor end of the temperature sensor through the hole in the back of the oven. Slide the sensor all the way until the sensor mounting plate is flush against the oven. Secure the sensor with the two mounting screws.
  • 7
    Connect the sensor wire to the connector by pushing the connector until it locks in place. Snap the wire inside the retaining clip.
  • 8
    Place the back panel back over the rear of the oven and secure the panel with the retaining screws. Slide the Kenmore oven back into its working position and plug the power cord into the wall outlet.
  • Oct 09, 2011 | Ovens
    How do I replace my oven element
    Hello.
    Theoven is a particularly sturdy piece of kitchen equipment. It can handle dailyuse and still perform as needed. But of course, as with everything over time,the oven can eventually have some things go wrong with it. The first signs maybe subtle, like your cake not being cooked through, or you may notice the oventaking much longer than usual to come to temperature. When looking inside theoven as it is heating, you may notice tiny sparks along the bake element. Anyof these symptoms may mean it's time to replace the bake element.Instructionsand tools below Screwdriver, Newbake element, Electrical tape, Fiberglass tape, Flashlight1 The first step when it comes to working on yourelectric oven is to turn the breaker off at your home's service panel, orbreaker box. This is extremely important, because most electric ovens require220-volt electricity to operate, and that voltage won't only hit you hard, itcan kill you. Place a sign on your breaker panel stating that you are workingon the electrical. As an added precaution, unplug the oven from the walloutlet. Remove the drawer below the oven chamber to see if the plug isaccessible from there. Otherwise, you may have to pull out the oven a bit tounplug it.2 Be sure that the oven has not been used in a whileand that the elements are completely cool. Remove all of the racks from insidethe oven. If it makes it more comfortable, you can even remove the oven door byopening it and sliding it off of the "arms" that hold it in place.3 Locate the bake element. It resembles a metal tubethat's been bent into a square shape and it is located on the bottom of theoven's interior. It can be quite dark inside the oven, so grab your flashlightand shine it to the rear of the oven's interior to locate where the bakeelement is connected to the oven wall.4 There will be two screws holding the bake element inplace. Remove the two screws and place them somewhere where you will not losethem. Now, pull the bake element out of the oven wall. There will be wiresattached to each "leg" of the bake element. Note: There is usuallynot much wire to work with, so do not pull too hard. Once you have about 4 or 5inches of wire exposed, place a piece of black electrical tape over the wire atthe point where it enters the oven. This will help keep the wire from fallingback inside the hole.5 At the point where the wires are connected to thebake element, you should see a screw. Remove the screws and separate the wiresfrom the bake element. Keep the old element for reference when shopping for anew element that matches the old one exactly.6 Install the new element by connecting one wire toeach leg of the element with the screws, just as they were with the oldelement. Wrap a layer of white fiberglass tape around the terminals. Push thewires back through the holes in the rear of the oven until the bake element isback in position. Use the screws to secure the new element to the oven wall, asbefore.7 Replace the oven door if you removed itearlier. Plug in the oven, then turn the breaker back on. Turn on the oven andtest the new element. You may notice some smoke coming off of the element as itheats up for the first time. This is ok, as these are just oils burning off ofit. The smoke will stop in a few seconds.Thanks.
    Sep 28, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
    I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
    You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
    *** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
    Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
    Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
    Apr 13, 2011 | Ovens
    The element has blown on my Zanussi ZBF860 oven. I
    You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
    Mar 15, 2011 | Zanussi ZBF360 Electric Single Oven
    What does it mean when a gas cooker needs hardwiring
    It means that it does not have a cord and a plug to just plug it into a wall socket...
    It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
    heatman101
    Dec 13, 2010 | New World G60m Gas Single Oven
    I have a GE Profile Wall Oven. JT910SASS. The cooling fan makes a loud noise. How do I replace it? Where is it?
    Firstly, you don't need to replace your fan simply because it's noisy. It may be sufficient just to grease the spindle/bearings.
    The fan is located at the back of the oven and CANNOT be accessed from inside the oven. If you open the oven door, you will see a grille at the back of the oven compartment - basically just some slots and holes cut into the back panel. Behind this grille is the heating coil/element, then another panel, behind which is the fan/fan motor. Basically, the fan is right at the back, dead-centre of the unit.
    To access the fan, you will need to remove the oven from the wall cabinet and remove the back panel. To do this, you first need to unplug the oven or, if it's hardwired, detach the cable from the outlet - power off please! Next, remove the retaining screws at the on both sides of the oven at the front - these are only revealed when the door is open. You should now be able to remove the oven from the wall cabinet by pulling it forwards gradually and feeding the power cable through as you do it. I suggest getting someone to help you lift it out as they are fairly heavy and awkward to hold/carry. Also wear some old clothes as the bottom of the unit can be quite greasy!
    Put the oven somewhere safe where you can access the back of the oven easily. The fan is covered by a removable back panel. Undo the screws (about 10) around the edges of the panel and partially pull the panel away - taking care not to snag any of the wiring behind the panel. You will also need to remove the connectors to the main power cable to remove the panel fully. Make a note of the connections (or take a photo) to ensure you reconnect it correctly!
    You should now have clear access to the fan. Inpsect it visually to see if the blades are broken and try spinning it by hand to identify where the noise is coming from. If the blades are sound apply some HMP grease around the spindle which rotates the fan. This can be quite tricky, so it might be easier to liberally apply some spray lube around the area. Spin the fan by hand a little to work the lube in.
    Next, test the oven before putting it back into the wall cabinet. This can be done by replacing the back panel and plugging the oven into a socket or extension cable. If the oven was hardwired, attach a plug to the end of the cable. Turn the oven on at the minimum temperature and let it run for 5-10 minutes to allow the lubricant to work through. If the noise has diminished or gone, reinstall the oven in reverse order of the above. After refitting, I suggest running the oven empty on a low-mid temperature until the smell of lubricant has gone.
    If the fan is damaged - or you can't get rid of the noise by lubricating it - then you will need to buy a new motor and fan blade. Fitting these is easy with the back panel removed as they simply bolt/screw onto the back panel of the oven and the wires just slide on and off. If possible, take some photos before removing the old fan/motor to ensure correct fitting of the new parts.
    Please post back if you need further assistance.
    Hope this helps.
    BElectric
    Nov 02, 2010 | GE Profile JT910SASS Electric Single Oven
    Shows F2 E1 no buttons work?
    Sounds like a shorted keypad error(F2-E0). I do not see a F2-E1 error listed. You will need to pull the top front panel off and verify that the keypad wiring harness is fully seated. You might want to try removing the harness then re-plugging it back in. Inspect the wiring for shorts(exposed wires). And make sure the appliance is unplugged from the electrical outlet before attempting any repairs.
    Jan 16, 2010 | KitchenAid KEBC107 Electric Single Oven
    Why doesn't a new electric oven go flush to wall when installed
    The configuration of the electrical supply often prevents the oven from aligning the same as the previous unit. The supply box on the wall can be relocated or recessed and that will usually solve this issue.
    Nov 30, 2009 | Ovens
    Oven has power; wont heat
    It's mounted on the rear of the oven. First, turn off the circuit breaker, then the oven must be removed and the back panel taken off to access the TOD (thermal overload device). Its mounted right flat against the oven rear panel, with one large red wire attached on each end. If the TOD is open, that means the rear of the oven got too hot or the TOD failed (its a safety device). You can connect the two wires together and insulate with electrical tape, restore power and test the heaters to make sure the TOD is actually the problem. They haven't ever solved this problem...the most current answer is to replace the TOD with a new one, but bend the mounting tabs so that when the new part is installed, there is a space between the TOD and the oven sheet metal about the thickness of a dime. Then reassemble and reinstall the oven.
    Apr 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
    Double oven / convection not working
    It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
    Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
    Ovens Logo
    49 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
