Question about Acer X233H 23 in. LCD TV
I have a Acer X233HBID 23 in, flat panel computer monitor (without TV tuner). I want to use it, instead, as a TV in my kitchen. Is there some kind of external TV tuner that I can plug into it?
  • 11,361 Answers
ACER S231HL Monitor Won't come on
What kind of power cord does it take...with or without attatched box?
Feb 21, 2015 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
How do I get my cable channels?
Depends on the 'TV', some have built in tuners, so you should have a 'connector' that has threads, it is called an 'f' fitting. If your flat panel is branded as a 'Monitor' then it does NOT include the tuner. Most cable companies carry two tiers of service. The old 'analog' channels and the new digital channels. Your TV has to have a built in tuner or you have to connect it to a 'STB' (Set top Box) especially true if you only have digital channels, in which case how you connect to the TV/Monitor is based on the types of connectors both support. You should be able to use HDMI (carries both video and sound), but the channel selection will need to be done at the device that has the tuner.
Without more details, I cannot be more specific.
Aug 06, 2014 | Televison & Video
Can this monitor be used for tv?
you want to watch tv on it? it has no tv tuner so you may buy a tv card for your computer. every monitor as far as i know may be used to watch tv trough yor pc tv card.
May 28, 2013 | Xerox XL592DB 19" Flat Panel LCD Monitor
How can i use my acer monitor as a tv i lost my manual
The manual won't help you to much in this regard.
This monitor is a standard type that has both a VGA and DVI input.
Normally what you would use with a personal computer.
If you want to use it as a TV monitor you will have some sort of device that outputs to VGA or DVI.
DVI stands for "Digital Visual Interface" and it's preferable over VGA as it should potentially give you a better image.
This means:
A) A computer. You can build your own media TV and watch internet streamed shows like Hulu, Netfix, use as a DVD player, etc. I recommend this route. No more dependance on Cable companies! You just need internet.
B) Find a DVD, and, or Tuner/Cable/Satellite box that has these outputs.
If you want to use Cable or Satellite, contact your provider company and see if they have a box that will output to either VGA or DVI. Might have a hard time finding one of these, or it might cost more then it's worth.
C) Buy a S-Video input to VGA/DVI output. You can buy these for around $40.
Then you should be able to hook it up to just about any device as most modern TV devices will have an S-Video outputs.
Feb 17, 2011 | Acer AL2032WD 20" Flat Panel LCD Monitor
We have PN 455 LCD monitor, can we use this as TV without connected to PC or TV tuner box.
No, since it is only a monitor it doesn't have a TV tuner built-in. You would either need a PC with a tv tuner card, or a cable box.
Aug 17, 2010 | Sharp PN-455 45 in. LCD Television
Bought new monitor but cannot get sound
when you bought the monitor did a cable with a jack that looks like a earphone jack come iwth it if it did you need to connect that to the monitor and to your computer tower
Sep 15, 2009 | Acer X233H 23 in. LCD TV
TV TUner external not starting up
Safe mode
Power saving off
restart normally
Jan 30, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Tv tuner card is not supporting with lcd monitor
The intex it 3488 tv tuner has known compatibility problems with this particular Acer monitor: see here.
If the tuner card is new see if you can get a refund, by claiming it as faulty, after all this is a factory fault.
Sep 08, 2008 | Acer AL1916W 19" LCD Monitor
MONITOR
You will need a TV Tuner expansion card for your computer. If you buy a TV Tuner expansion card and install it, and connect an antenna or cable TV cable, you will be able to watch TV shows on your computer monitor while using your computer. With some TV tuner cards, you can also record TV for watching it later, or even hook up your VCR and record VHS tapes and home videos to put on DVD. This is a more complicated topic and instructions should come with the TV Tuner expansion card you purchase.
TV tuner cards usually run in the range of $20-75 and will fit in most computers. You can buy them online and at computer or electronics stores. Installation is fairly simple and the instructions and software are included (unless you buy a used one)
Jun 10, 2008 | Sharp LL173C 17" Flat Panel LCD Monitor
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
Acer X233H 23 in. LCD TV Logo
175 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
