Question about Whirlpool Duet GHW9150P Front Load Washer
F33 fault ineed a schematic - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 3,740 Answers
An F33 code = check pump. Usually coinds or gunk get into the pump and the impeller stops turning. Open the front and remove the filter sump. Clean it out and look for debris in the pump. Yu can also get this code if the small vacuum looking line that connects to the water level presure switch is clogged. Slide off the small tube from the presure switch and see if you can orally pass air through the hose. If not clean in the area where it connects to the bottom of the unit.
If you clean the sump / pump and your sure that air passes through the small tube the washer should work normally again.
Kelly
Posted on Nov 07, 2010
  • Kelly
    Kelly Nov 08, 2010
    I did not just start doing this recently.
    http://blog.fixya.com/index.php/2010/05/...
    I have done in home appliance repair since the late 1960's. I passed you what you needed to do to save your self a ton of money. I get rewarded with a 2 Thumbs Up for passing on a few decades of experience for free. Clean out your sump and check the pressure sense line going to the water level float switch for obstructions and you should be back to normal the same day. The only thing that may take longer is if the pump has actually failed and you need parts. Unless the pump smells like it burned up; cleaning out your pump sump and sense line will get you going again.
    Feel free to ask any questions necessary to get your washer going again. Responding with a poor rating and no comments from you does not get your washer fixed. I only wish to help you and save you lots money.
    Kelly
  • darren_spark
    darren_spark Dec 24, 2012
    Excellent advice, all the hoses were clogged and pump and filter, cleaned all these but still showing pump error and clean pump, disconnected pressure switch hoses and clear, reconnected and blew in and there was a blockage at drum end which cleared and machine fixed, thanks again
May tag dryer fault f33
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Sep 02, 2016 | Washing Machines
Fukuda tv schematic diagram
ineed schematic diagram of fukuda tv ft21asnf9-vx
Jan 27, 2014 | Washing Machines
I need a wiring schematic for the SBEC for a 1991 dodge spirit
Most auto parts stores have PETERSON repair manuals that have schematics for every major system in a vehicle.
Jan 02, 2014 | 1991 Dodge Spirit
Kenmore elite he4t f33
The F33 code can indicate a bad pump or a problem with the wiring either at the pump or the CCU (central control unit), or the wiring harness itself. Before you replaced the pump, did you test the resistance in the wiring harness?
Unplug the washer and use an Ohmeter (VOM) to test. See http://media.fotki.com/1_p,wtftddqbdtwbdkrxgtqsskgwtqkq,vi/tgdkbwkswxfddbwsbdbxtbgtgwftb/1/1303472/5961857/image49983img-or.gif for the schematics of the wiring for the pump on the CCU. To access the CCU, you need to remove a few screws on the back of the top panel. You remove the lower service panel on the front of the washer to access the pump. The wiring should read 12.3 ohms at the CCU. If you get a reading of infinity (open), check the pump. If the leads to the pump motor give a resistance of 12.3 ohms, then the wiring harness should probably be replaced. If the circuit to the pump is fine and the error persists, then the CCU is faulty and needs to be replaced.
I hope this helps. If you add a comment with the specific model of your washer, I may be able to give additional suggestions.
Dec 23, 2012 | Kenmore Washing Machines
Everytime i try to run a load of wash i get a F33 error - what can i do?
Please clarify the Model and Make of your Washer.
The F33 error for Whirlpool: The "F33" error code means that the washer has encountered a system error with the pump drive. The parts should be working fine; it is just the connection that caused the problem.
Check connectors on central control board.
Mar 09, 2011 | Washing Machines
HDW 1011WG machine showing a F33 fault
The error F33 means Pump Drive System Error occurs when the connection between pump and the Central Control Unit(CCU) is lost.
Follow these steps.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit(CCU).
3. Plug in washer or reconnect power.
4. Verify CCU operation by running a Diagnostic Test or any cycle.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting a S2 and a f33 fault and the washer is not draining what is the problem?
Hi, "F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Apr 10, 2010 | Kenmore HE2 Plus Front Load Washer
PANASONIC CU160C53XP
BEST WAY IS TO GET AHOLD OF THE MFR'S TECH SUPPORT LINE EASILY OBTAINED FROM YOUR SERVICE MANUAL OR INFO (NOT SURE OF STATE)
Dec 16, 2007 | Fedders A6P09S2A Air Conditioner
Whirlpool Duet GHW9150P Front Load Washer Logo
164 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
