Question about Mtd Garden
HOW DO i LOAD TRIMMING LINE ONTO THE TRIMMING HEAD OF MY MTD LINE TRIMMER MODEL # MTD LT31C REV POO?
  • Anonymous Mar 28, 2014
    Is there a chainsaw extension attachment for the MTD Pro BC263RS Line trimmer
    President:
  • Mtd Master
  • 1,545 Answers
Please see pages 19 thru 23 of your owner's manual. Detailed instructions with diagrams are here.
http://dl.owneriq.net/8/895c4a8d-d94e-49d4-5d45-dc71cf8a717a.pdf
You will need Adobe Reader installed (free, safe, download) installed on your computer to view this.
Posted on Nov 09, 2010
How do you pull out more line on toro 910 home trimmer
The feed bump located on the bottom of the unit is the portion of the head that you tap on the ground to feed more trimmer line as you are trimming!
Mar 18, 2017 | Toro Garden
Trimmer line runs out FAST
Check the spring tension, if the spring is weak, line can be fed out too quickly.
May 09, 2015 | Husqvarna Garden
Need diagrams on how to wind line onto brushcutter spool model mtd pro bc230c-rs
Howdy Geoff,
There are basically 2 basic types of spool heads that are wound. This link will walk you through both types. Once you've successfully wound it once, it's not too difficult. http://community.homedepot.com/t5/What-s-New-in-our-Garden-Aisles/Replacement-String-Trimmer-Head/m-p/151/highlight/true#M4
Coach Dave
Oct 27, 2011 | Garden
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
The motor is working but the trimmer part stopped spinning. I checked the line but there is plenty, I removed and replaced the line spool but still not working.
Does the trimmer head spin freely? If so then it is somehow disconnected from the motor. There should be a motor coupler somewhere near the motor and also near the trimming head. Make sure they are connected.
Jun 06, 2011 | Black & Decker 14" Grass Hog Xp...
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
What is the 2 Stroke Mix Ratio for a Yard Machine
Most are 40:1 but if you go 50:1 to be safe it will be ok.
Jan 12, 2010 | Mtd Garden
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
134 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
