Question about Dell Latitude E4200 Notebook
How do I connect my Latitude E4200 to a external Monitor?
5 Suggested Answers
Vader50
  • 11 Answers
SOURCE: connection to external monitor stopped working
Did you go to the display properties screen and check the settings of the second monitor connection. You must turn it on, and have it set to a low enough resolution for the monitor to work. If it shows the second monitor, Click Identify and it will put a number on the laptop screen. Which ever number doesn't show up is the external monitor. Select it and set the resolution down by grabbing the scroll bar and drag it to the left. Start at 800x600 or so and apply changes. If the monitor doesn't come on, check to see if the monitor is on.
Posted on Mar 30, 2009
Bat1956
  • 585 Answers
SOURCE: LCD dim.
If you have replaced the screen and the inverter, about the only thing left is the flexible cable from the monitor to the video card. I take it that the Fn+F8 makes no difference?
Posted on May 23, 2009
SOURCE: dell latitude e4200 manual
All types of manuels are available in the link below,
http://support.dell.com/support/edocs/systems/late4200/en/index.htm
hope this helps.
Posted on Nov 30, 2010
nonontech
  • 4737 Answers
SOURCE: LCD Monitor Dell Latitude D630
It would be better if you could let me know the Monitor Model so that I can make this specific. This Laptop has VGA port to connect External Monitor. Vga Port shown below:
You'll need a VGA cable like this :
You'll find another VGA port on the monitor (shown below), connect the one end of the vga cable to the monitor and the other end to the Laptop's vga port.
That's all you need to do, but make sure everything including the monitor and the cable is working. Once you turn on the laptop, the display should show up on the monitor which you'd need to configure (if necessary).
Let me know if you have problem doing this.
Watch this video (Click Here)
Good Luck.
Thanks for using FixYa.
Posted on Dec 13, 2010
Dell latitude D630 wont recognize projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 19, 2012 | Dell Latitude D630 Notebook
Latitude E5400 screen flickers when external screen connected, extrenal screen OK
Please try to:
check the highest resolution of the external screen then set the resolution of your laptop base on the capacity of the external screen right click on the blank section of your screen then click properties then go to settings choose one like 1024 x 768 press ok plug the external monitor make sure the cable is in proper position then power on the monitor enjoy
thanks for using Fixya
May 31, 2011 | Dell Latitude C400 Notebook
My Del Latitude C400 screen will not work how do i plug in an external monitor
connect to external monitor with 15pin connector. and there is one function key is there with symbol of monitor. at the time of booting presss that key external display will come
Jun 16, 2010 | Dell Latitude C400 Notebook
Dell Latitude L100 monitor not coming on
For the external monitor when you have it plugged in do you press fn f4 depending to switch from the lcd to the external monitor?
May 20, 2010 | Dell Latitude 100L Notebook
When typing on the E4200 the lcd screen starts to go dim is this a know problem
Check the battery & also see if it happens when plugged in to the a/c adapter.
May 04, 2010 | Dell Latitude E4200 Notebook
My dell l e4200 has screen problem, when I boot it up nothing is showing even if I press fn-f8.
There can be several reasons this is happening. The first thing I would suggest is testing the video card by connecting an external monitor to the laptop. If that works, the cable connecting the laptop screen or screen itself may have been disconnected/damaged/gone bad. If it doesn't work, the video card may have gone bad.
Apr 08, 2010 | Dell Latitude E4200 Notebook
When i turn on my dell latitude D505 the backlight
Either the video cable has been damaged or unplugged or the video processor is malfunctioning. Check this by connecting an external monitor. If the video is all there then press the Fn(function) and F4 key. This should switch the video from the external monitor to the internal screen. If this doesn't happen or if the external monitor shows no video then the laptop needs to see a reputable repair perso or check my website www.micromendllc.com
Feb 25, 2010 | Dell Latitude D505 Notebook
E4200 Poor sound quality: no bass whatsoever
How much bass do you expect from a speaker less than an inch in diameter? Have you tried using an external surround sound system? It is unrealistic of anyone to expect stereo polyphonic digital audio from a speaker the size of earphones, unless of course they are earphones, and in that case they are designed to operate at lower volume because they would be on your ears.
Nov 05, 2009 | Dell Latitude E4200 Notebook
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Problems with external monitor
Typical issue is the second monitor resolution got set too high for the monitor to generate a picture. Go to display settings and adjust the resolution down to see if it comes back.
Mar 30, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Dell Latitude E4200 Notebook Logo
347 people viewed this question
Clive
Clive
Alun Cox
