Question about Keurig B100 Coffee Maker
I have a Keurig b100 I ran water in it and emptied it out about 10 times had coffee grounds was working fine prior to that now when I plug it in the outlet it trips the switches. It made 4 beeps prior to this happening? Not sure if I screwed it up.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
Posted on Mar 01, 2011
When I try to brew a cup of coffee on my keurig b100 water leaks back into the resevoir and I only get half cups.
If you are experiencing inconsistent brews, there may be some coffee grounds lodged in the needles that pierce the K-Cup packs. This video will show you how to SAFELY clean this area of the brewer
Aug 28, 2012 | Keurig B100 Coffee Maker
Tip
Unclogging a Keurig
Thread approximately 12 inches of 50 lb. nylon fishing line through the opening in the sharp metal point. This threads more easily when the coffee maker is hot. Continue running water through the unit until a full cup is achieved and water runs clear with no coffee grounds.
on May 20, 2011 | Keurig B100 Coffee Maker
Coffee maker is on. will not make coffee,will not take more water. just sits there like it is dead. descale light came on first. cannot descale because it will not take or give water. help olease.
I would first empty out any water that is in the machine, and get the grounds out. Then, the machine up with a 50/50 mixture of distilled water and white vinegar. You may need to let this sit in the machine overnight because the vinegar needs time to work it's magic. Then turn it on and run this mixture through, if the machine is descaled enough to run. If it doesn't, do it again. The key to descaling is the vinegar, but like I said, it needs time to dissolve the scale. If it works, then run a couple of pot's of just water to get rid of the vinegar smell. Give it a try!
Feb 13, 2011 | Keurig B100 Coffee Maker
I have a keurig mini and the water is barley dispensing. I dont know if its clogged or what. What can i do?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 04, 2011 | Keurig B100 Coffee Maker
It is stuck on large and does not brew
My keurig did the exact same thing. Stuck on large and wasn't pulling water into coffee maker so it would only dispense a small amt of coffee. I turned it off for about 10 mins. Emptied the reservoir and filled it half way with white vinegar. Ran several cups through and after 2nd brew it ran faster and after the 3rd run with vinegar all the size cup lights came back on. It is working great now. Just empty reservoir with remaining vinegar and rinse. Run a couple cycles of plain water through the coffee maker to rinse out vinegar. I hope this works for you.
Dec 27, 2009 | Keurig B60 Coffee Maker
Keurig b100 does not shoot water in the K-Cup, It
Either it is scaled up and needs to be cleaned or the air pump is bad.
Nov 08, 2009 | Keurig B100 Coffee Maker
B100 putting out very little water, reservoir is full
bye descaling product for the coffee maker not vinegar put descaler in machine fill with water start leave it running for 10 seconds close it for 15 minute start it up again repeat untill empty after its empty fill it with water run it untill empty repeat again descaler is acid so you need to rinse very good try it out thanks pierre
Jan 11, 2009 | Keurig B100 Coffee Maker
Can I hook up a water supply to a Keurig B100 brewer?
The B100 is a pour over unit and the drain is just that.. a drain directly connected to the tank... In order to have plumb feature the machine would need a fill solenoid attached to a float.switch through a circut board of sorts...Hope this helps
Robb
Nov 25, 2008 | Keurig B100 Coffee Maker
Leaving my Keurig plugged in all the time?
dont leave it on for nothing it cost you electricity the machine wont last that long and for water harding dont make the same mistake as everybody do they dont descalcified calcium a killer on machine use descaler product not vinegar vinegar remove calcium in pieces you might block the machine descaler product melt calcium do it every 3 mouth 1 part descaler 1 part water fill up the water tank activate the machine open valve let it drip for a few second stop for 10 minutr repeat untill empty rinse very good a few water cointainer thanks for using fixya pierre
Feb 05, 2008 | Keurig B100 Coffee Maker
Keurig B100 Coffee Maker Logo
115 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
