I have a pltv 32c. i get no red light and have no power. there was a guy that say he checked cord and the fuse. i have checked the cord, but where is the fuse to check that???
  • 11,361 Answers
Posted on Nov 07, 2010
Testimonial: "this was very helpful!!!! thank you very much"
Power supply is OK (indicator light does go on) but we have no picture; Can you tell us what connector cables we need for this model (PLTV 32; Model LU32A1A3) Thank you
PLTV-32 or 32C?
PLTV-32 uses AC adapter that puts out 12vdc (for sound and logic) and 24vdc for the backlights inverter board. Do you get sound?
PLTV-32C uses built-in power supply that usually has 24vdc failure due to bad caps or bad circuits.
Try this first:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 25, 2010 | Protron PLTV-32 Television
My Protron 32" tv went blank, is there a circuit
no breaker .most likely a fuse firs check the out let with a lamp to Se if it work,s be for you take the TV apart.
Dec 23, 2010 | Protron PLTV-32 Television
Hi have a protron and can't seem where the plug to connect it is can you please help me
You mean that you don't have the A/C cord running out the back? If not there is a small black hold in the back of the set that you have to plug this type of cord in, if you don't have try places like walmart, home depot, or any electronic store.
Dec 04, 2010 | Protron PLTV-32 Television
No prower to tv plug and outlet OK
PLTV-32 uses AC adapter tah puts oit 12 and 24vdc, the PLTV-32C uses internal power supply. You need to check the DC output of the AC adapter or go in side to check the power supply module.
Please see my basic troubleshooting guide here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 07, 2010 | Protron PLTV-32 Television
Protron PLTV-32C, Model No. LT32C1P1 just went black as we were watching. It did it last night but within seconds the picture came back on. Now it went off and is staying off. Didn't realize at first but...
Mother board Is My Guess That's What's Wrong With Mine And Part Is $250.00 My Problem IS Can I Replace it By Myeslf . I Had Mine looked At .By So Called Professional He Kept it For 8 Months.
Aug 31, 2010 | Protron PLTV-32 Television
Protron PLTV-32C, 3 years old Have always used the cable remote to turn on TV. Cable turns on. TV will not turn on but, redlight is on. Tried powering manually, tried both the TV remote and the cable...
Tries unplug the tv and the cable box about an hour and replug both.See if the tv reset it self and the cable box reboot it software.Not,than the Tuner board is dead,that the board the coalax signal cable plug into it to get the broscasting signal.
Jul 14, 2010 | Protron PLTV-32 Television
Protron lcd tv getting no power
I have the same problem. I am told that I need a new power supply (adaptor) but from what I am reading on the Net, they are very rare and TV repairman told me he cannot find the part. I heard that Protron is out of business.
Jun 03, 2009 | Protron PLTV-32 Television
Ultra PLTV-32. Replaced the power cord supply assembly. The light goes from red to yellow but no picture?
Apr 02, 2009 | Televison & Video
Protron pltv 32 tv
funny that no one's been able to help you, because I accidentally discovered that the power supply cord for my computer worked for my Protron PLTV-32C lcd...  not sure if your model is different in someway, but you may want to try the cord from your own PC first,
and if it works.
Jan 25, 2008 | Protron PLTV-32 Television
Power cord
Guys try lcdpayless.com
$139.98 that includes shipping!!!
Jan 01, 2008 | Protron PLTV-32 Television
Televison & Video Logo
218 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
