Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
My vacum e2000 electrolux dont start after i changed the bag ?
    Novelist:
  • 147 Answers
Try putting the bag in again. There is a kill switch on your door usually in the bottom left as your putting the bag in. Make sure that your bag covers that kill switch and your vac should start again.
Good luck.
Posted on Nov 07, 2010
Testimonial: "thank you !!!!"
  • Donna Oct 31, 2011
    Worked perfect. THANKS
  • RANDALL Dec 07, 2011
    You fixed mine as well, thanks!
My vacum will not start a red question mark lights up. Can this be fixed?
This light indicates the bag needs changed. If you've done that, The possibilities are a clogged hose, clogged elbow at power nozzle, or on certain models a bad Control Valve Assembly. If yours has a dial on top, turn so the smallest dot lines up with the arrow. If it doesn't have a dial, you don't have to worry about a bad CVA. If you aren't using genuine Electrolux bags made by Home Solutions, then the bags pores will clog faster, which would cause the vacuum to shut off.
Jan 09, 2011 | Electrolux C101 Bagged Canister Vacuum
Vacum shuts down when suction starts
Try turning the knob on the top of the vac all the way to the right.
Jul 04, 2010 | Electrolux Guardian Bagged Canister Vacuum
Is the style c the right bag. The vacum cleaner only runs about 5 seconds before it says the bag is full.
If you have a 6500, the C bag is the right one. Try turning the dial on top of the vac to the smallest dot and see if the machine will run properly.
If it is still doing the same thing, take it to your Aerus/Electrolux dealer for repair. The control valve assembly (full bag control) needs to be replaced and I don't recomend that you try the repair.
Joe
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
Need to open the electrolux vacum
The locking key on the side of the vac has a tightening wedge on it so it doesn't slide easily. Spray the entire key top and bottom with WD40 or similar. Grasp at the bag door area with vise grips and pull the key straight forward.
If the key will not slide, you will need to take a large flat bladed screwdriver and lay the blade flat at 90 degrees against the back end of the key. then strike the side driving the key forward toward the bag chamber door. Do not twist.
Aug 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I have a Electrolux Epic 6500 SR canister vacum cleaner. It is nine years old and for the past few weeks it has started shutting off for no apparent reason.The symbol for bag change lights up and it cuts...
Your machine is probably clogged, look through the wands, look in the bottom attachment, to see if there is anything stuck there. You can also drop a marble through the hose itself to see if anything is stuck there as well. To unclog the hose try holding the attachment end of the hose were you would normally plug the hose in. ( the goal is to **** the clog out the way it came in).
Aug 18, 2009 | Electrolux Harmony Canister Vacuum -...
Vacuum won't stay on
When you open the canister you eill see a little rubber hole that senses when your bag is full. This must be clogged. If you have another vac try to vacume all the dusr from this hole and any other opening inside the vacume that you can reach. I hope this helps. Don't forget to rate this answer.
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Help me fix my LUX7000
Turn the dial down to its least sensitive setting and try that. If not you can call my office at 570-326-1731
Oct 20, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
612 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
