Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
DLink Wireless router was working on desktop yesterday when i installed it. Move the computer to a different area of the house, now laptop will work but desktop wont
  • D-Link Master
  • 7,733 Answers
Check if your PC recognize the router.If not probably you need to keep moving it until the PC get the signal.
Posted on Nov 07, 2010
LENOVO G780 WiFi problems
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 02, 2013 | Lenovo G780 2182 laptop
I have a century link westell 7500 wireless router to which I would like to connect a D-Link Wireless n Powerline router to get extended range to other areas of my house. I have connected it according to...
Try moving your laptop closer to the range extender. If it connects then you know the range extender isn't extending the signal enough. So then either move laptop or maybe extender.
Oct 30, 2017 | Computers & Internet
Diconnect internet connnection every 2-5 min (d-link dir100)so pls help ...
try using different PC or laptop or move to different location dependign on the streght of the signal and also make sure that dlink is properly connected. or unstall anr re-instal your Dlink if it does not work your dlink may be defective.
Oct 08, 2010 | D-Link (DIR-130) Router
I have used this router for 2 years inone home attached by cable to a desktop and at the same time set up for wireless for other laptops in the home. I have got a new router for that house, but want to use...
1. Yes, clear the router for the new house.
follow these instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 03, 2010 | D-Link DSL-G604T Wireless Router
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
DWL-G510 cant find network
please, is there anybody who can help me with the setup cd(installation cd) for d-link airplus dwlg510.
Jun 26, 2009 | D-Link AirPlus G DWL-G510 802.11g/b...
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Not getting internet on my laptop
What you can try is :
re-install wireless card
power cycle your router & modem and then try to connect
if it still does not work then call your internet service provider and he ll assist you with the settings
Nov 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless and Wired Router
I have dlink DI-524 which is hooked to my desktop but wireless option is not working. I would like to use wireless option for my laptop.
Jul 25, 2008 | Computers & Internet
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
