Question about Poulan Pro Chain Saw 46cc 20"
Can start the saw but when beginning the cut the saw power declines and will not cut. Please advise
    Brigadier General:
  • 4,088 Answers
The chain may need proper sharpening--it should not have to be forced to cut quickly. Make sure the bar and chain are being oiled enough. If the engine speed does not decline much, but the chain speed slows down, the clutch assembly may be full of oil (remove the cover and wash out the clutch with spray carburetor cleaner). Make sure the chain is properly tensioned--it should be tight to the bar, but able to be moved fairly easily by hand. Check the fuel filter and air cleaner for plugging. Make sure the fuel lines are in good condition. Hope some of this helps!
Posted on Nov 07, 2010
My poulan 4018wt has been a hard starter from new. It started to act up out of the blue and started shutting off halfway into the cut and didn't always want to idle right. So I changed the spark plug,
I'd say the most probable culprit is the fuel.... I'd first try dumping the tank out, mixing fresh gas with the addition of a fuel stabilizer and start the saw. It'll quickly vent any old gas in the line and should begin to run fine with the new mix. If not, consider returning it to the service center for adjustment.
Never use gas that has sit on a shelf for months at a time as it becomes 'stale' (for lack of a proper term). Todays 'formulated fuel' can be a cause a bit of a problem for some small engines. Anytime you refuel, shake the can to remix prior to filling.
The oxygenated nature of the blended gas sometimes causes the chain saws to run a little 'lean'...meaning too much air to fuel ratio which could be a portion of your problem. A lean running saw will run hot and scoring of the piston or cylinder wall is possible. Some finely tuned professional saws need carb adjustments between the summer blend and the winter blend gas.
Mar 24, 2015 | Poulan Garden
Tip
Benefits of using a scroll saw
Some times there are woodworking projects that you will want to do that can be very difficult to do with a regular power saw. There are several big benefits to using a scroll saw over other saws due to its ease of use and control.
Lets say that you want to make a jigsaw puzzle, you could use a jigsaw saw that has to be mounted on a table because they are difficult to control or you could use a scroll saw that is a mounted saw to begin with. You will also find that a scroll saw allows for more control and has much less vibration than a jigsaw.
The cuts that a scroll saw make are so smooth that in most cases you won't need to sand down the edges. This is a really helpful feature when you are working on cutting difficult to get into angles and cutting inside a piece.
The ability to make an interal cut without having to start the cut from the edge of the piece of wood a huge advantage over most other saws. When you want to make a cut out all you have to do is drill a hole in the area you want to cut out, and then slide the blade through the hole and use the scroll saw to cut out the edges. There is also a foot pedal that you can use so that you can keep both hands on the piece so it doesn't run away when the blade starts moving.
Many power tools tend to be very loud, which lends themselves to the user working alone with earplugs of some other forms of hearing protection. The scross saw is a very quiet power tool that is perfect for you to teach your kids about the art of woodworking. And it is safe enough that they can use it to build their own model airplanes and artwork.
on Feb 02, 2014 | Saws
Tip
My Blue Laser
Ever wish you could make that perfect cut the first time with your miter saw or table saw ? Simple if you put a strip of wide blue tape on base of saw and cut the tape with your saw ! Now you know where the blade will cut, now mark your wood, move the wood and the pencil mark to edge of tape that you just cut and cut it. That simple and easy to calibrate verses the red lasers that come on some saws that to me never work right to begin with.
Valley2118
on Feb 19, 2010 | Saws
Stihl Ts410 hard to start and erratic running
http://www.mediafire.com/download/dk8dipzr69pksrk
I've added the breakdown manual for you, have you replaced the fuel and air filters. could be a simple issue of not being able to draw up the fuel from the tank. Stone saws deal with a lot of dust and this seriously effects their running and also their cooling capabilities.
Jan 31, 2014 | Stihl Saws
PLEASE advise as to HOW TO INCREASE VOLUME on my Uniden DECT 6.0 Thank you
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
Saw starts but as soon as begin cutting saw stops stops
The engine is running too lean, start by removing the fuel hose from inside the tank and replace the filter on the end
Feb 19, 2011 | Stihl Garden
Saw will not cut curves
Tighter curves have to be cut by cutting tangentally; that is, when the blade will not follow the line any further, you cut away from the material line that you are trying to follow, and begin again by bringing the material back to the blade.
Best regards,
--W/D--
Jan 20, 2011 | Craftsman 3/8 x 62" Band Saw Blade, 6 tpi...
Chain saw cuts great at start, not so good about 1/2 way
All things are possible but it isn't likely the bar is bent. Are you getting fairly large chips or sawdust? Try raising the rear of the saw a little when she quits cutting. so you have a small contact area instead of a wide flat cut. Run a flat file at an angle along both edges of the bar to remove any wire edge. Let me know what you find you have piqued my curiosity. Lou
Oct 01, 2009 | Garden
Circular saw engine question
it's important to choose a tool with a motor that is powerful enough to meet your needs. For example, a woodworker should choose a saw with enough power to cut through everything from wet lumber to dense hardwood. If the motor in the saw you select doesn't have enough power, the blade heats up and begins to dull. In addition to creating poor quality cuts, this can become a safety hazard if the blade starts to climb out and push the saw back towards the user. However, evaluating power from the motor ratings can be misleading. Amps indicate only the amount of electricity a motor draws, not the power it sends to the blade. Horsepower accounts for torque (rotational force), but not necessarily under working conditions. So be careful and ask the seller if this particular tool suits the work you want to be done.
Aug 27, 2008 | Bosch SR6R180 180 Grit 6" Disc 6/Pack Red...
Poulan Pro Chain Saw 46cc 20" Logo
89 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
