Question about Apple iPod touch
Ipod touch i have no sync from ipod to itunes i have tried to restart the apple mobile device but it will not stop first. unistalled reinstalled itunes latest vevsion unistalled just about everything still no joy can you help pls
  • Apple Master
  • 13,433 Answers
Ipod classic won't sync with itunes 10
Restarting your computer is often the solution when your iPod fails to sync with your iTunes music library. But if this fails, there are other troubleshooting steps to take.
Recharge your iPod via a USB cable connected to your computer or AC adapter. b> Click the help menu in iTunes and check for updates. Follow the onscreen prompts to download and install the latest version of the software. Open the new version of iTunes. Click the name of your iPod in the source list and check for updates under the summary tab to update your iPod. Attempt to sync your iPod with iTunes. Slide your iPod's hold switch to the hold position and then to off. Press and hold the menu and center buttons simultaneously until the Apple logo appears to reset your iPod. Open iTunes on your computer and reconnect your iPod to try to sync it with iTunes. Restart iPod service b> Close iTunes and make sure your iPod is disconnected from the computer. Click the 'start' button. Click 'run' if using Windows XP. Type 'services.msc' in the run box in XP and in the search box in the start menu in Windows 7 and Vista. Press 'enter.' Scroll through the list and double-click on 'iPod service.' Click the 'stop' button and leave the properties window open. Connect your iPod to the computer. Open 'my computer' or 'computer' and look for your iPod listed in the devices with removable storage section. Click the 'start' button in the iPod Service's properties window. Open iTunes to attempt to sync your iPod. Close the iPod Service's properties window once your iPod has finished syncing. Resolve "Original File could not be Found" Double-click the name of a song in the iTunes program that failed to sync to your iPod. Click 'yes' or 'locate' to the message asking you if you want to locate the file. Navigate to the folder or directory location where the song is stored on your computer. Double-click the song file to select it and add it back to iTunes. Reconnect your iPod to the computer and open iTunes to restart the syncing process. Some songs in iTunes won't copy to iPod http://support.apple.com/kb/TS1420 iPod classic Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/classic/
Apr 12, 2013 | Apple iPod MA446LL/A MP3 Player
Tip
How to back up an iPod Touch games
<p>When you download games on your iPod touch, they are applications on your mobile device. When you connect your iPod Touch to a computer with iTunes installed, the iPod synchronizes and shares data with the computer. Once synchronized, you can back up your games and other applications in the iTunes case something would happen to the data on your iPod Touch. After the first sync, every time you touch your iPod to your computer, iTunes automatically detects new applications and backs them up. <br /> <p><br /> <p>1. Launch the iTunes software on your computer. <br /> <p><br /> <p>2. Connect your iPod Touch into a USB port on your computer using the cable supplied with the unit. <br /> <p><br /> <p>3. Let the iPod Touch to sync with the iTunes software. The "Sync in Progress" message will appear on your iPod during the process. <br /> <p><br /> <p>4. Click the name of your iPod Touch to the left of the iTunes window. On the device displayed in the right pane. <br /> <p><br /> <p>5. Click on "Applications" tab on the top menu. <br /> <p><br /> <p>6. Click the box next to "Sync Apps", and attach the sync as the pop-up window will appear. <br /> <p><br /> <p>7. Click the "Sync" button in the lower right corner. This makes a backup of your iPod Touch games on the computer. <br />
on Aug 05, 2011 | Apple iPod touch
Restore software for ipod 16GB touch
i would be checking the usb lead before doing anything or even replacing it with a new one make sure iis securely connected
the cable near the iTunes symbol represents a problem with the cable
and the cd will not not be able to activate without a connection
Connect one end of the USB sync cable to one of your computer's unused USB ports, and connect the other end to the bottom of the iPhone or iPod Touch.
If iTunes does not start on its own, run it using the desktop or Start menu shortcut.
When iTunes starts, you should see an icon for the iPhone or iPod Touch on the left side of the window.
Click "Summary" in the right pane of the window if it is not already active.
Click the "Restore" button to begin the device restoration process.
ITunes displays a message asking if you want to save the contents of the device to your computer before restoring it.
If you have not backed up the device already, click the "Back Up" button.
If you have already done this, click "Don't Back Up."
Click "Restore." ITunes clears the data from your iPhone or iPod Touch and reinstalls the device's original firmware.
The screen of your iPhone or iPod Touch may shut off while iTunes works.
Do not remove the USB sync cable.
When iTunes is done restoring the device, it displays a message letting you know that the device is about to restart.
Click "OK" to restart the device. If you are restoring an iPhone or iPod touch, wait for the "iPhone / iPod touch is activated" message to appear on the screen of the device before you disconnect it from the computer.
You may now restore your backup of the device or remove it from the computer.
hope this helps
Sep 15, 2012 | Apple iPod touch
I just bought ipod touch i cannot do anythiing because all you can see is itune logo
The iPod Touch gives users the ability to enjoy videos and music while on the go. Users can also surf the Internet on the iPod Touch. Before you can start using the iPod Touch, though, the device will need to be activated. When you activate the iPod Touch, you will register the device and sync the player with your iTunes account. Completing this process will allow you to purchase content from the pre-installed App Store and iTunes applications found on the iPod Touch.
1. Connect the Apple iPod Touch to the computer using the iPod Touch USB cord.
2. Open iTunes on the computer.
3. Click the word "iPod" underneath the "Devices" menu, located on the left part of iTunes.
4. Click the "Continue" button in the middle iTunes window. Then, click the "License Agreement" box. Click the "Continue" button once more.
5. Enter your iTunes Store account information inside the middle iTunes window. Then, click "Continue." Then, type in the requested personal information (such as name, address, etc.) to register the iPod Touch with Apple.
6. Click the "Not Now" button on the "Mobile Me" page to skip this step. Signing up for Mobile Me isn't necessary for activating the iPod Touch.
7. Select the "Set up as new iPod" option inside the middle of iTunes. Enter a name for your iPod Touch inside the text box that's in the iTunes window. Then, click "Continue."
8. Choose one of the sync settings listed in the center iTunes window. Whether you decide to manually or automatically sync your iPod Touch with iTunes is up to you--you can change this setting at any time. After you've selected a sync setting, click "Done." The iPod Touch will be activated. From here, you can add music to your iPod Touch or disconnect the player. Only disconnect the iPod Touch after you see the "OK to Disconnect" message appear at the top of iTunes.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Computers & Internet
Setting up new Ipod Touch 8gb
Reinstall iTunes. That's the easiest way to fix this problem. But don't uninstall it. Just download the latest version from Apple run it and restart your computer.
Apr 04, 2010 | Apple iPod touch
Need to restore apple mobile device helper
youll need to reinstall itunes, and ipod software onto the computer. Then it should pick up your itouch and you can restore it.....if it doesnt work which it may, youll need to send it in to apple. I had an older ipod it showed up with apple support site, and i had to send it in to them!
Aug 12, 2009 | Apple iPod touch
Forgot my passcode
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
Jun 20, 2009 | Apple iPod touch
8 gig ipod songs are cleared, but they are still taking up space
Sometimes you need to restore the iPod even though you've already deleted the content. Below I have posted a step by step for restoring your iPod touch in iTunes. If you are still unable to sync the iPod after restoring please do let me know :)
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
May 14, 2009 | Apple iPod touch
I'm having trouble just turning on my itouch... I just opened it and tried plugging it into the itunes... and it tells me "This ipod cannot be used because the Apple Mobile Device is not...
Your computer must be connected to the Internet.
By default, iTunes automatically syncs all songs and videos in your iTunes library to
iPod touch. If you have more content in your library than will fit on iPod touch, iTunes
alerts you that it can’t sync your content. You’ll need to use iTunes to select some of
your songs, videos, and other content to sync. The following section tells you how.
Read the rest from your manual at:
http://manuals.info.apple.com/en_US/iPod_touch_Features_Guide.pdf
Jun 20, 2008 | Audio Players & Recorders
Ipod not recognized by computer or itunes
contol panel / administrative tools/services/ press stop on apple mobile devices and then start again this should work.
Jun 15, 2008 | Apple iPod touch
Apple iPod touch Logo
32 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
