Question about Caterpillar 18" Remote Control Excavator
When i us the remote to go forward or other up ways i doesent work
Gear alignment on outboard motor
When the gear box ix in forward, it should make a ratcheting noise when rotated forward and should not turn at all when turning in reverse (or be resistant as your back spinning the water pump -don't do that) Once in gear (forward ) you should be able to mate the shift to the motor. I have removed the prop and nut and used a remote start to spin every thing together, but requires a lot of safety precautions.
If you are working on an older mercury, that shift rod can work both ways with disastrous results if you over spin the shifter to the back side of the detent.
Sep 17, 2012 | Boating
How do you change the birghtness on a admiral tv without remote?
well you can try over here :http://www.radiomuseum.org/dsp_hersteller_detail.cfm?company_id=702
Aug 02, 2012 | Cars & Trucks
Universal remote that work?
There is a way to program the comcast universal remote to the TV. If you still have the programming instructions, use the automatic search/ program function instead of manualy entering the product code. This usually works better since some TV manufacturers sell the same TV under other product names. Good luck. Please leave positive feedback if my answer is useful. Good luck
Jul 22, 2010 | Haier HTF20R21 20" TV
I am unable to set up my directv remote to shut off and on & volume up and down on TV
hi,
make sure slider on the top is all the way over to the left then..
hit menu down arrow to parental, favs, setup hit select down arrow to system setup hit select down arrow to remote down arrow to tv choose brand in right list find code
MOVE SLIDER ON TOP ALL THE WAY TO THE RIGHT POINT THE REMOTE AT YOURSELF HOLD DOWN SELECT AND MUTE UNTILL LIGHT BLINKS TWICE
ENTER CODE
LIGHT WILL BLINK TWICE AGAIN
TRY THE BUTTONS
IF IT DOESENT WORK TRY A DIFFERENT CODE
OR GOOGLE DIRECTV CODES
NAVIGATING THE DIRECTV WEBSITE FOR CODES IS NEARLY IMPOSSIBLE. GOOGLE CODES.
JM
Jan 24, 2010 | Televison & Video
My cd changer on my m reg 940 volvo doesent work
try puting a lazer cleaner through it
Dec 29, 2009 | Car Audio & Video
Tv remote code
sorry - but if the codes that came with the remote dont work then you need a different remote with the right make & model.
place were you bought it should change it for another one.espeailly if they told you that that one would work.......
Aug 07, 2009 | Televison & Video
Security will not reset
The disarm switch on the latch inside the door is most likely defective, pull the door panel and test it for proper function.
Oct 01, 2008 | 1992 Cadillac Seville
Lost remote
hi,
did you try channelling up- down all the way? is there a menu button on the front? if there is you might be able to using the menu buttons and the chan up down or vol up down to navigate, if that doesent work then yes probably have to get a universal. any newer universal remote should unlock it. Newer directv universals will work for sure..
J
Jul 11, 2008 | Disney 13" TV
Samsung SP42W4HBX Remote. Nothing works
hello my tv had the same problem needs a new power board cost around 35 would be cheaper 2 get part an pay sum 1 to fit thanks
Jan 04, 2008 | Samsung TV Remote Control
Ipod wont work
The problem is "ipod dock receiver connector"(connector is fuck), move forward and backwards the ipod just point the ipod can play the songs..
try you!
Dec 25, 2007 | Apple iLive IBCD3816DT Portable 2.1...
Caterpillar 18"  Remote Control Excavator Logo
Top Caterpillar Toys Experts
fordexpert
Ted Maxwell
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
