Question about M-Audio Audiophile 192 Sound Card
The delta ap192 has 3 pairs of connections in the back. is there a diagram that could show me the best way to connect all of them between my computer and 1 external mixer that i use for basic sound source selection and an amplifier from where my speakers are attached? i am a visual person and pictures and images help me a lot. any diagram or step by step directions would help. i am sure it is not a problem with the equipment itself as i can test that sound is coming out. thanks
  • Brett Duxbury
    Brett Duxbury Jun 02, 2017
    Hi t1200, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    What make and model number is your mixer ?
    Does the mixer have an analogue input or a digital input ?
    The delta ap192 has S/PDIF coaxial output on a standard RCA jack Digital ouput
    or a TRS 1/4 inch analogue left and right out off the midi breakout cable.
    So it depends on what the mixer can use as an input ????
    you will find the user manual for the delta ap 192 athttp://www.m-audio.com/support/documents...
    under legacy devices
    Delta Audiophile 192
5 Suggested Answers
  • 23 Answers
SOURCE: Connection to Mixer
I am not sure about that brand but on my Roland Speakers, the TRS jack lives inside the XLR. I first missed it. Take an XLR and try to connect. I can't imagine that they would not have XLR especially for studio monitors. Also are your speakers passive or active, that is something that I would seriously at. No amplitude, low signal, no active.
Posted on Aug 29, 2007
cancerags
  • 36 Answers
SOURCE: Connect BX8A speaker to PC
Hello waddragon,
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be.
It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine.
Let me know how it goes.
cancerags
Posted on Dec 28, 2007
  • 86 Answers
SOURCE: hearing double voice when monitoring through delta 1010
Check to see if you have your onboard sound turned on. If you do turn it off and this should stop the double voice.
Posted on Jan 08, 2009
  • 11 Answers
SOURCE: my guitar is connected to the mixer, which in turn...
plug guitar into fast track, to mixer, to speakers
Posted on May 26, 2010
I have a Garmin 2010c on my boat and turns off every 10mins.. what can be the problem?
Bad connection or a fault to the unit.
Do you have it on a separate battery? It is best if they are, or connect direct to the starting battery, not connected via power that you find in the console or on a power bar.
Make sure you are using good quality copper stranded wire of the correct gauge with soldered or properly crimped connectors. I think it is 18 gauge, but your installation instructions will guide you. Also mentions 24 AWG. Manual states;
Wiring
There are two wiring diagrams provided for you convenience. The first is a simple hook-up showing the GPSMAP 2006/2010 (using the 18-
pin wiring harness), the GPS 17 and the alarm circuit. The Alarm does not have to be wired for the unit to function. The second is a complete
wiring diagram showing the GPSMAP 2006/2010 (using the 18-pin wiring harness) interfacing with a variety of different equipment. The extra
5-pin wiring harness that came with the unit is intended for future interfacing features and does not require connection. Refer to the wiring
diagram that will best suite your needs. Make sure that all connections are good. For extra lengths of wire, 24
AWG (unless otherwise noted on
wiring diagram), shielded, twisted-pair wiring is recommended. We advise soldering all connections and sealing the connection with heat shrink
tubing. If you experience difficulty wiring the unit, please contact an installation professional in your area.
Make sure the connections are good on the rear of the unit including plugs to the transducer. You can coat with a little Vaseline which his electrically conductive.
States the unit is susceptible to RFI and should be 3 feet away from a radio antennae.
Finally, make sure the inline fuse and connections to it are good.
If all that seems good, the first thing to do is swap out the transducer for a new one. Still does it? Send the unit for repair.
Does it also do it at rest in the marina, or do you trailer the boat?
I have a Humminbird 998 HD Si.
http://static.garmin.com/pumac/47_2006_2010_GPS17Installation.pdf
Jul 29, 2017 | Garmin GPS
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Based on the Delta Force Schematic and the Turner +2 diagram 1=White 2=Red 3=Black 4=No connection (Unless you install 2 scan buttons in the Turner +2) 5= Shield Switch the internal switch in the bottom of the microphone for Electronic Switching (Not Relay). :-)
Aug 24, 2014 | Radio Communications
Need wiring diagram for 230 v for delta table saw cat. #36-451
Is the motor designed for dual voltages? The manual does not have a wiring diagram. I assume the motor lable diagram is faded or missing.
Dual voltage motors contain two sets of winding. Each set is rated for the lower voltage. To operate the motor on the higher voltage the windings must be connected in series. AND, they must be connected in the same direction. I use a variac to apply 30-40 VAC to the coils in various combinations, then measure the open lead voltage to determine the proper connections. This test should be performed by a licensed electrician.
Dec 05, 2013 | Delta Saws
I need a color coded wiring diagram for a peavey PV115 speaker cabinet.
Usually the colors you will find are red and black pair and yellow and white... USUALLY the red/blk pair go to the tweeter horn with red going to the + lead of the horn drivers. Usually the yellow/white pair go to the woofer with the white going to the + lead of the woofer in Peavey speakers... HOWEVER you never know if someone has rewired the cabinet so going by colors is NOT the best way to go... This should have the "soundgard" circuit in it and the lead that goes throught the lamp and resistor that is NOT connected to the inout jack is the TWEETER + lead. The pair that connects to the inout jack DIRECTELY is the woofer leads and the TIP connection of a 1/4 inch jack is the + woofer lead. Verifying these connections is the best method.
Aug 15, 2011 | Peavey PV 115 Speaker PA Passive
IF I HAVE A MOTOR WITH STAR DELTA WINDING AND NO LABELING IS DONE HOW WILL I CONNECT THE CABLES TO THE MOTOR
the motor will have 3 pairs that can be checked with a ohm meter for continuity. each pair has a start and a finish. usually it would be labelled U1 V1 & W1 for the start and U2 V2 & W2 for the end or finish.
To connect in star ( Motors that start with direct load ) supply cables to U1 ( Red ) V1 ( White ) W1 ( blue ) and bridge out U2 V2 & W2.
To connect in delta Supply cables as above. Bridge U2 to V1 - Bridge V2 to W1 - Bridge W2 to U1.
If you have a reversed winding the motor will growl and not turn.
To reverse direction of rotation swap any 2 supply cables ( But only when the power is OFF )
Mar 09, 2011 | Kitchen Ranges
Who to wirie star delta starter
This site gives an excellent explanation of the star connection and the delta connection.
Answers.com - How do you wire a star delta motor
Then this site shows the wiring of the motor windings and the star delta starter and what occurs when the starter switches from star to delta.
Moeller - Star-delta switching of three-phase motors - Automatic star-delta starters SDAINL
Good luck.
Dec 20, 2010 | Air Tools & Compressors
Wired my delta 10" table saw for 220v and breaker on motor pops and it is wired to manul specs?
Not sure this will apply, but most motors that can be setup for either 110 or 220 will have leads inside the motor connection box that need to be reconfigured to convert the voltage. If you simply rewired the plug over to 220V, then you will need to redo the leads inside the motor as well.
Jan 15, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Original radio wiring harness
Google Volvo wiring diagram. They are available free. The diagram shows the wire location and colors. Otherwise, run a continuity test with a simple meter to discover a connection with some resistance between a pair of wires. If you here a click or two, from the speakers, you have found the right pair. Continue and label the pairs left, right, front,rear, until all are identified. Then reconnect. A pain but not rocket science.
Nov 06, 2008 | 1991 Volvo 240
New phone wire from box to home need diagram to show how to
The phone company should make that connection. Use a phone jack assembly with alligator clips to find the dial tone. The first line color should be a pair, blue&blue-white, 2nd line, orange& orange-white, then green followed by brown pairs which would be 4 line numbers in that color code order. Each line is just a single pair. Thank you. Jer
Feb 25, 2008 | Lands Phones
Connecting durabrand SA51AR
COnnect to the CD/MP3 audio pair.
Dec 28, 2007 | Durabrand STS92 System
M-Audio Audiophile 192 Sound Card Logo
80 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
