Question about Capital Cooking Precision GCR364BN Gas Range
The oven gas burner does not ignite all the time. An intermittent problem. I have replaced the solenoid and it worked fine for a couple of weeks and now is intermittent in lighting again. It worked perfectly for about three years until this problem showed up. Intermittently the oven will not ignite but after about 90 seconds a light tap on the solenoid with a knife handle or screwdriver instantly ignites the oven.
  • graffiti655 Nov 09, 2010
    Hello again, I have checked the ignitor, it always works. The venturi is clean and clear. I checked all the wiring I could see and it checks ok. Turn oven on I can't hear any gas into the burner. When I turn on the griller in the top of the oven after about a minute I can hear the whistle of the gas and the grill ignites. Not so with the oven.
    Cheers, Michael
    President:
  • 2,468 Answers
Does the gas ignitor ALWAYS glow upon call for oven ignition? if not,then check for any grease/cooking residue near the venturi tube,loose connections as in wiring(which I believe is your issue due to the intermittant problem with the new solenoid) which you need to tap to make it operate,check ALL wiring closely first,because a poor or intermittant connection will not let the safety circuit open or close it off in case of a failed ignition try
Posted on Nov 07, 2010
LG5791XSWO
The symptom you have indicates weak solenoid coils. The gas valve should open and the burner should ignite every time the glow bar igniter glows before it fades back off. Weak solenoid coils will usually open the gas valve until the solenoids become hot from the current and flame and then they don't have enough power to open the gas valve.
Replace both solenoid coils and your dryer will most heat and operate normally again. In order to access and replace the solenoid coils you will need to remove the front panel.
Here is the coil kit to order.
Nov 06, 2012 | Whirlpool Dryers
Oven gas ignitor turns on and the gas solenoid does not open gas valve to ignite burner.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 14, 2011 | Ovens
Oven "bake" burner wont ignite on a gas oven.
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
My GE oven takes a long time to lite. When it finally does there is a small explosion sound. I already replaced the ignitor 2 weeks ago. It worked fine for about 1 week and now I have the same problem...
If the gas valve is opening in a reasonable amount of time then the problem isn't with the igniter and you don't need to bother testing amp draw... Could be a number of things, clogged burner ports near the igniter, incorrect air/ gas ratio, incorrect igniter position (too far away from the burner), incorrect gas pressure. If you can, watch the burner when it lights from a safe distance and see if both sides are igniting at the same time or if it just builds up gas until BOOM! Ha ha, hope you figure it out, be careful.
Oct 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas oven won't light on Tappan Centenniel. First, the burners come on, so gas is getting to it. When oven thermistat is turned on, some sort of electric igniter element glows. How does this igniter...
The inside of igniter has a probe that is heated, When it is time to light, the solenoid opens gas valve and allows gas, then that heated probe ignites the flame. After temp is reached fuel is shut off.
Oct 29, 2009 | Kitchen Ranges
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Oct 11, 2009 | Viking Ovens
My oven won't heat
First you will need to verify if the igniter is coming on for the oven burner when the oven is turned on. You will need to remove the oven bottom cover. There is usually two screws at the back bottom of the oven compartment that holds the bottom on. If there are no screws then it should just lift out. You may need to slide the bottom away from you then lift from the back. You will need to remove the oven racks to make enough room to lif the bottom out. Once removed you should be able to see the burner(you may also need to remove a heat spreader on the burner). Now turn on the oven and watch for the hot surface igniter to start to glow. If it does then you will need to make sure the gas orfice and venturri for the burner are not plugged with debris. You can use a small can of compressed air to try and dislodge any debris. Then give the oven gas valve a light tap with a screwdriver or a wrench. Oven gas valve is usually located at the bottom of the oven. Remove the bottom storage compartment to reach it. If you tap it and the burner comes on there may have just been debris in the valve and you may have cleared it. Then turn the oven off and back on completely several times. If the burner comes back on you should be ok if it does not then it could be a weak hot surface igniter or a bad olven gas control valve. Now going back to the start if the igniter does not come on you will need to verify if the igniter is getting voltage. If it is then test the igniter with a ohm meter. The reading should usually be between 500 to 700 ohms. A common problem with hot surface igniters is that they will crack. Examine the igniter for any visible cracks. If the igniter is not getting voltage then you will need to verify that all wires are properly connected and none have come loose. Look for any melted wires from the self cleaning process. You may need to dis-assemble the back of the range to see if any wires have come loose or melted. Now I need to stress to you that safety is important. Be very careful performing these procedures. You can get shocked or possible burned.
Oct 06, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
Whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Aug 20, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Capital Cooking Precision GCR364BN Gas Range Logo
98 people viewed this question
Top Capital Cooking Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Capital Cooking Kitchen Range Expert? Answer questions, earn points and help others
