Question about Coleman Proforce 6 Gallon Air Compressor
I have a Pro Force Air Compressor. Model # VPP0200604. The gauge shows 150 pounds of pressure but I can only get it up to 40 pounds. Any ideas as to what is going on? Thanks
harlan301
  • 205 Answers
SOURCE: i need a part for VPP0200604 PRoforce air
that made by powermate which is out of business no part. you can check with pramc co which owens that division know. 800-445-2276
Posted on Oct 14, 2009
  • 10 Answers
SOURCE: Where can I get a new intake filter for my model
try e-bay thats where i got mine
Posted on Nov 24, 2009
  • 243 Answers
SOURCE: my small pro force reaches a certain pressure and
hi, sounds like the safetyvalve is opening. there is a opening value on the valve, check this at moment of opening. if it opens at correct value, your pressure regulator is set to high. to lower this you have to open the regulator, (is the small case where the wires going in) and release the bold in the spring.(unplug first before opening, life parts) if the problem stays the same, make sure that the pressure out of the tank will reach the regulator. there is a small hole witch can be closed by rust or dirt. good luck, you can always aske for more options.
Posted on Mar 01, 2010
  • 1388 Answers
I do not use factory parts when possible to repair compressors. I use generic pressure switch, checkvalves, guages from www.grainger.com. Watch port size, number of access ports and unloader availability when ordering. Pressure switches are generally replaced when contacts are burned or over pressurizing to point of safety opening. If compressor is not reaching set pressure look for leaks or faulty parts in pump. Good luck
Posted on Sep 14, 2010
  • 1274 Answers
SOURCE: 27 gal upright tank, 5
Hi, my name is John. Welcome to FixYa. Yes, its your pressure switch,replace. Thanks for choosing FixYa...John
Posted on Nov 23, 2010
My Ingersoll Rand UNI15-5-150-L rotary screw compressor only starts uo after trying to start between 10 and 15 times
image Regulator may difference on all set ups good luck
you may have a Regulator on Air-Compressor Mount on the Gauge or next to it this allow you to set a pressures from 0 - 200 psi this to helps you maintain steady and reliable operation of your air tools.
Apr 18, 2013 | Ingersoll Rand Stationary Air Cooled...
35 pounds of pressure in air conditioning system but 0 when compressor turned on
Detect refrigerant leakage in the system, repair and recharge the gas
Apr 08, 2013 | 2005 Honda Civic 1.7i
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
Hello. I have a Ingersoll Rand air compressor, model 2475. I was wondering if there was a way to adjust the pressure gauge to create a larger differential. It is currently running between 150 and 160...
You can adjust almost all pressure switches
Compressors,Well Pumps,etc
Take off the cover & there should be a screw
to do just what you want to do,lower the cut out
pressure
Good idea, as the compressor will last many years
longer, the less it runs
Jun 29, 2011 | Ingersoll Rand - Rand Type - 30...
My husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
May 27, 2010 | Air Tools & Compressors
EC119SA less than one yr old just has started showing signs of low air volume. Was using it to clean off work bench, first blast of air was strong then quickly has very little pressure. The pressure gauge...
hi there, if there is enough air pressure present in the compressor the motor will stop,the pressure switch is working.if there is a good pressure at start then suddenly lost the pressure,there is no maintaining pressure to use but on the pressure gauge appear to be have a good or enough air pressure. check if the pressure gauge have enough air pressure the motor is stop,meaning the cut out limit switch stop the motor,if you loosen the air pressure from the valve until the cut in pressure attain or meet the motor will run again there will be a cycle process of differential pressure of cut in and cut out set up on pressure switch. checking the compressor,be sure there is a high pressure on compressor and the compressor motor is stop,shut off service valve and disconnect unit device / tools from the service valve. if the compressor have enough air pressure crakc down the service valve and observe the pressure until it run again the compressor motor,if the pressure maintain the pressure you need to clean the bench, the problem is the unit device/tool you use is defective, but if the maintaining air pressure in the compressor is lost due to malfuction of motor and the compressor engine. check the pressure switch, check the motor function by loosening the belt and run the motor w/o the compressor engine if it is tripping brought it to service center, check also the lubricant oil,if neccessary change oil.have a nice day and fix my rate thanks a lot.
Apr 20, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
No air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
Nov 06, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Need a unloader valve for a ProForce model no. vpp0200604 air compreesor
Need to know the desired pressure for your compressor, please dont exceed the compressors capabilities
Jul 13, 2009 | Air Tools & Compressors
Will only charge to 40 psi, is supposed to charge to 150
You may have a problem still related to the original reason it was reconditioned.
However, you should have a regulator that you set to the tank pressure you want to maintain. Most have a tool regulator as well and 40 psi sounds like that is what it is set for.
If you do have a tank pressure regulator and it is still not charging above 40 psi, then either take it back or pick up a new regulator for under $20 at Home Depot and replace the gauge you have now.
Also, sometimes the gauge will have a needle tilted so that one end presses against the glass, and if you tap the glass hard with your finger it will move on around to the correct pressure.
Finally, if you are not experienced with small compressors, look under your gauge and see if there is not a black knob that pulls out and pushes in to turn and change the pressure.
Sirwriter
May 21, 2009 | Stanley Factory Reconditioned Bostitch...
Broken Part. Need Replacement
If you refer to the oil filler plug, item #6 in the diagram linked here, it's listed as obsolete.
If refer to the intake filter, It's item #3 on the diagram, it too is listed obsolete.
http://www.mastertoolrepair.com/vpp0200604-vp0200604-p-14827.html
I would contact Master Tool Repair at 757-410-2879. They can cross the part to another once they know the thread size of the old part.
Mar 15, 2009 | Coleman Proforce 6 Gallon Air Compressor
Coleman Proforce 6 Gallon Air Compressor Logo
49 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
