Question about Maytag EPIC MFW9700S Front Load Washer
F01 EROR CODE FLASHING - Maytag EPIC MFW9700S Front Load Washer
    President:
  • 2,468 Answers
Normally an F01 code is considered a POWER FAILURE error,unplug and see if the units ecu electronics will reset themselves,otherwise,it can be a wiring problem(especially a small ribbon cable) within the unit,unplug each connection and check for any corrosion,(look closely) as these cables/wires carry only small signal voltages and any corrosion can hinder signal paths.,if not then the ecm controller needs replacing
Posted on Nov 07, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Dec 17, 2013 | Maytag Dryers
Wont start, error code f01
The F01 error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. This type of failure generally requires replacing the Central Control Unit (CCU). You could try disconnecting the power cord for a couple of minutes and then reconnect the power cord. If it continues to flash "F01" I recommend calling a service technician to remove and replace the CCU.
Jan 16, 2011 | Dryers
Maytag f-o1 code , says change ccu board, I did but still the same , is there a clear code I do if so how Maytag epic z
Unplug the unit for 2 1/2 minutes. Does the problem return? Open the top, check all of your connections going to your CCU. Are any loose? Also try following the black hose on the top, right hand side towards the rear. It goes to your pressure switch (round cylinder 2 1/2 - 3" wide). Give it a firm tap with something insulated (the handle of your screw driver for instance). If the switch gets stuck it can cause a false f01 eror code.
Jun 19, 2008 | Maytag Washing Machines
I have a maytag EpicZ, model # MHW2600TW00 with an error code of F01. Do you know how to clear this code?
I just had this problem and I kept the washing machine on and flashing f01 and I pulled the power cord out of the outlet while it was still on and it reset it and I could start washing immediately.
May 27, 2008 | Maytag Washing Machines
Maytag EpicZ has a F01 code. The machine will not start!
I have had the same problem and I just fixed it. The f01 code was flashing and I left the machine on and pulled the cord out of the outlet and it restarted. Mine would not start, it would power on and you could select the type of wash and make any selection, but once you pressed start it would start flashing f01. I left if flashing and pulled the plug and it started working immediately.
Apr 15, 2008 | Washing Machines
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
Error Code F01
F01 is not a valid fault code but if it is displaying that and all the lights are flashing the main computer has gone haywire. Possibly the display board (in the plastic panel that houses the buttons) may be faulty but this is unlikely
Sep 28, 2007 | Kenmore Elite 45986 Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
197 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
