Question about Cameras
How to erase pictures from my memory card? - Cameras
  • 43 Answers
Your mcamera has an option to erase pictures, but you didn't mention what make and model camera you had. Try the menu option to find it. If not that, look for an alternative method on the camera using some of the buttons in combination or alone with the picture displayed. The manual will also tell you what to do or you can download a manual for most cameras from the manufacturer's web site.
Alternatively, you can plug in the memory card to your PC (this may require a USB adapter) and look at the memory card as if it was a hard disk drive. You can then delete pictures directly from the PC. This will also allow you to back up your photos to your hard drive or CD/DVD writer if you have one.
Posted on Nov 07, 2010
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
How do I format a memory card without erasing pictures already on it?
No, format will erase all data. Try doing chkdsk <drive letter> /f in the command prompt.
Dec 22, 2012 | SanDisk 4GB Secure Digital High Capacity...
All my pictures are gone off my LUMIX camera that I took only a few hours ago. The pictures ARE on my memory card, as it shows it when i put my memory card into the computer. But it won't show it on my...
First, it sounds like your mode dial is set to "clipboard". While it is, with no card in the camera, press the delete button to erase the clipboard memory. Then, set the mode dial to normal picture mode. Still, with no card in the camera, press the delete button again to erase anything from the internal memory of the camera. Then, insert the card and it should work properly.
Dec 24, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
Pictures will not load to memory card
first of all make sure you have choose the memory card as your default option to save pictures. if you are sure about this, secondly make sure your memory card is working. the golden boxes ( metal plates) in memory card should not be covered with dirt so make sure you erase the gold plate with a eraser(rubber) and make sure it is gold in colour and re insert it into your camera . else try with a different memory card
Aug 31, 2010 | Nikon COOLPIX P80 Digital Camera
I used to be able to take 1000+ pictures on external memory card. Now I'm trying to take pictures and it will only allow me to take 9 pictures but on the camera memory. I have reset the camera to factory...
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the format thing again (This will erase your card so if there are pictures on it, download them first using a separate card reader).
Jul 02, 2010 | Olympus SP-565 UZ Digital Camera
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
Picture card
You can buy a cheap multi card reader at an office supply store, Best Buy, a computer store or a photographic supply. Use the card reader to read your memory card from your computer
Feb 15, 2008 | Fuji FinePix 1400 Zoom Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
