Question about Princeton Digital Computers & Internet
My monitor flashes on and off as well as its power button. I can't bring up its menu either. It;s a Princeton VL1918mithy
  • 11,361 Answers
It can be caused by many failed components as shown in my picrues here:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Look for bad caps first since it is easy to do.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 07, 2010
Describe your (VL1916) 19" LCD
Did you try this monitor with another PC and already verify that the VGA cable is OK.
Common problem with Princeton monitors are due to bad DC filter capacitors in the power supply board, see example here:
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
Sep 10, 2011 | Princeton Digital VL1916 19" LCD Monitor
When i connect the monitor VL2018W TO a power supply without connecting to my pc,i get the message ''NO SIGNAL,SELF DIAGNOSTIC'''.When i connect cable to pc,,there flashing blue light...
* Make sure the cable is connected properly.
* I've you have mutiple interfaces like HDMI & VGA, try switching between these until you get a signal :D
This can be performed by using the build-in options menu.
Jun 14, 2011 | Princeton Digital VL2018W Monitor
My Princeton monitor will show the normal screen for about one second when I push the power button, but then immediately goes off (screen is black). If I push the power button off, and then back on it does...
It more likely to have the same failure as other Princeton monitors here.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 11, 2010 | Princeton Digital VL1916 19" LCD Monitor
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
Princeton vl1918 flashes on than off
See previous solution for Princton Monitor cycling on and off.
Solution: Change out 3 capacitors.
Jul 15, 2009 | Princeton Digital VL1918 Monitor
Princeton VL173 scrren blank
Sounds like the monitor took a power surge. Monitor is probably bad but try hooking up the power to the monitor on a different power outlet and see if it turns on, if not then the monitor is bad and would need to be replaced.
May 04, 2009 | Princeton Digital VL173 Monitor
Princeton 19" lcd vl1918 BACKLIGHT replacement
On the bottom of your monitor or on the right side is a set of buttons one is for brightness and contrast try to reset the brightness and then contrast. If this does not work you may need a new monitor.
Jan 25, 2009 | Princeton Digital VL1918 Monitor
Princeton VL1715 monitor's pwr button is "locked." Can't turn-off
I have resolved this situation on other brands by holding down one of the advustment buttons while holding the power button in. You will see a message about "unlocking button" and a sliding bar if you find the right buttons.
Monitor Mike
Jan 06, 2009 | Princeton Digital VL17151 17" Flat Panel...
Key Lock?
Try this! Copied right from the Princeton Graphics support pages. (bless their hearts....'course it wasn't "real" easy to find; it was posted for a different monitor for a different problem... but it seems to work for different monitors... Mine's an LCD19D ... and no, it wasn't posted for my monitor either.)
Your EPROM needs to be reset. To accomplish this please
1) Power off the LCD
2) Unplug your VGA cable
3) Press the up arrow at the same time you power on the LCD monitor.
4) You will see a message "RESET EPROM" 5) Power off the unit
6) Plug in your VGA cable
7) Turn the power on.
--dadswank
Dec 23, 2007 | Princeton Digital VL1719 (Black) 17" LCD...
Please help me remove the Key Lock
Mar 07, 2007 | Princeton Digital VL1716 17" LCD Monitor
Computers & Internet Logo
154 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
