Question about Samsung HP-R5012 Television
I have a Samsung Plasma HP-r5012 that has sound but no pix. I had a repair man out and he said the main board needed replacing. I've decided to try and do it myself. I've found what I think is the part # but not sure if I can do this, or should I fork over the $ for him to do it?
  • Samsung Master
  • 8,457 Answers
U never done tv repair before,not sure about the parts or u think can't do it.Don't tries it.Shop for a new tv first and compare the repair priced that was quoted,if it cost more than half of the priced of a new tv.My opinion buy a new tv,prices are dropping very fast on Plasma and LCD tvs all models.
Posted on Nov 07, 2010
Where is zsus board located
Samsung 50 Plasma Parts ' eBay
www.ebay.com/bhp/samsung-50-plasma-parts
eBayFind great deals on eBay for Samsung 50 Plasma Parts in TV Boards, Parts and ...Samsung 50" PN50C430 LJ92-01728A Plasma Y-Main YSUS Board Unit Motherboard.... Part Number: LJ92-01705C (Partial PBA number (705C) can be found on a ...Samsung HP-R5072 50" Plasma HDTV Main Board BN41-00632A ...
Samsung Buffer Board Test and repair Part 1 - YouTube
? 11:20
https://www.youtube.com/watch?v=5hVi5gd0aec
Oct 5, 2010 - Uploaded by z28r2fast4u
I checked two buffer boards and found 11 out of the 12 ic's bad.... my samsung, I post the video here, do you know how to test YMAIN and ZSUS ? .... Samsung PN50C450 with a bad Plasma Panel Shows how to replace the ...
Jan 18, 2016 | Samsung HP-R5072 50 in. Plasma HDTV
Horizontal lines plasma screen
The details you provided here is not enough to provide a solution to this problem. Check http://electronicshelponline.blogspot.com/ This link. Pull up older posts there. Defective screen shots to plasma TVs are given. Compare them with your TV, and try to understand the fault. Most plasma screens will have similar circuit configuration, irrespective of brands and models. The only difference will be the number of circuit boards it contains according to its screen size.
May 28, 2013 | Samsung HP-R5012 Television
My tv won't turn on
Check and replace the man power regulator board as card basis. There is no repair to these boards of Plasma televisions. Replacing the power board is not a simple job. Check this link to get more details.
Jan 23, 2013 | Samsung HP-R5072 50 in. Plasma HDTV
Hp pl5060 Plasma TV has no sound or pix. Screen flashing white
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
Dec 15, 2012 | HP PL5060N 50 in. Plasma HDTV
Picture has gone pink and there is no sound - Samsung HP-T4254
It sounds like either the X-Main board or the Main Board has failed. I recommend calling 1-800-samsung to find the nearest service center to repair it. You can spend a lot of money replacing parts on a plasma before you find the defective part.
Jun 16, 2010 | Samsung HP-T4254 42 in. Plasma Television
Samsung HP-R5012
They didn't fix the issue this last time. The most common failure in these models is the upper and lower Y buffer boards. There are updated versions and both must be replaced as a pair. The part numbers are as follows: BN96-03361A for upper Y board and BN96-03362A for the lower Y board. Please take a few moments to rate my answer. Thanks...
Nov 20, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Hp-r5012
How long is a piece of string?
There are 2 boards called sustain boards inside the set. Either one of them or both could be the culprit. Unless you have electronic skill, the right tools and know how to retune the set, I would siuggest this is not a DIY job. Some willsay it is just a matter of unplugging the boards and replacing them, howver that is a short lived fix in a majority of the cases i read on here.
Yes it does work for a while, then other problems arise.. conergence drops out, power fails and a myriad of other things happen that would normally be measured and checked by a good repair technician. It ends up costing 2-3 times more than if it was done professionally. The decision is yours, but i can only advise you NOT to.
Thanks for using FIXYA
Sep 27, 2009 | Philips 42PF7220A 42 in. Plasma Television
I have a 50 in Samsung Plasma Tv that has static.
The dots your talking about is your Y- Sustain panel going bad. Have this taken care of ASAP, other boards can be damaged if it goes completely which will be a dead set or no pix with sound.
Jan 21, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung HP-R5012 Television Logo
230 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
