Question about 2wire 2700HG-B Router (2700HGB)
Wifi does not connect to internet (does not pull an IP Address)
  • 2wire Master
  • 7,733 Answers
The easiest way to access the HomePortal is to use another computer connected to your home network. If the DMZPlus computer is the only available computer, you can manually configure the TCP/IP settings on that computer. Modifying the following settings allows you to access the HomePortal user interface.
  • IP address 172.16.1.2 (valid IPs are 172.16.1.2 - 172.16.1.32)
  • Subnet Mask: 255.255.255.0
  • Gateway Address: 172.16.0.1
  • DNS Server Address: 172.16.0.1
Posted on Nov 07, 2010
What is my ISP?
Your ISP means Internet service provider.
not sure if they want IP address or company name of provider.
if you mean your WiFi you may have to do that at your home location to connect and enter your network password.
Then once connected they should be able to pair.
your notebook should have wifi settings under network wireless connection.
Sep 30, 2016 | Cell Phones
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
Continues to say acquiring ip address? Singnal strength is excellent! What's the problem?
Quite offer the user name and password have been entered incorrectly. The first action I take is to reset the router back to factory sitting and re-enter your details again. Remember that spaces and punctuation has to be entered exactly as required by your isp. Passwords and sometimes user names are case sensitive. To reset most router there is a reset button at the back of the router which needs to be pressed for up to 30 seconds with power on to complete the reset. Then check your computer/laptop /Tablet to make sure that the password you have used is correct. I start with the router because that is normally the most troublesome.
Oct 01, 2014 | Computers & Internet
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
I reset my modem and now i cant get my wifi back on
If your modem pulled a new or different ip address and you did not reset your router it could be trying to use the old IP address and there would be a conflict. IP addresses usually have a lease of 24 hours, S if your IP was refreshed at noon and you reset your mdem and for sopme reason it obtained a new ip address the router would not be able to connect until noon the following day when it tried to refresh. Rebooting the router should cause it to sync back up with the modem and pull the correct IP address. You may need to log into your router and manually release and renew the IP address even after rebooting your router, I have seen a few routers that would still not pull the new address unless this was done.
My preferred method is to unplug power from the router, then reboot the modem. Only after the modem is synced back up do I plug power back into the router, so far this has seemed to work the best.
Jan 30, 2013 | Smcd3gn-res Wireless Router Cable Modem...
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
IPod touch Wifi problem. I got a new iPod touch 4g and my dad got new pocket wifi so I tried to connect my iPod to the internet and it would work for about five minutes but then it would disconnect...
hi this sounds like the pocket wifi firewall or push is stopping you from connecting, it will show connection when the password is put in correctly, but unless your either ip, or mac address is registered with the unit it will not let you connect to the net, you will have to see if there is a start ip and an end ip address in the wifi unit, as this might have restrictions to ip address numbers..for example..wifi ip start address might be 192.168.0.1 and wifi end address might be 192.168.0.4 where as your ipod might have an ip address of 192.168.0.7 ( just an example ) so even though the password is ok, it will let you connect for that few seconds, as it has verified the password and is correct, but the ip handling has not allowed you access and the firewall then steps in and blocks you.... hope this helps
Jan 01, 2011 | Apple Computers & Internet
How to get the IP address to set my wireless
get the wifi signal detected by powering the wifi fro the laptopo
get connected to it (wifi)
go to>start>run>white cmd> write ipconfig/all>press enter
you will get the ip addresses of the wi fi router
give your laptop wifi card the ip address in the wifi router sequence
e.g. if wifi addresses:193.168.1.1
then your nonebook ip may be193.168.1.2
etc
have a nice day
please give me all thumbs
if problem is still there ask me again
Jan 26, 2010 | IBM ThinkPad R51 Notebook
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
2wire 2700HG-B Router (2700HGB) Logo
69 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
