Question about Samsung SyncMaster 940N Flat panel Monitor
Screen goes black after 2 seconds
Hi, my screen has a problem, it stays on for 2 seconds (after i switch it on) and after it goes completely black.
in those 2 secs the image is perfect, no problems.
but it works only for two seconds.
the blue light of the on/off switch remains lighted like when the screen is on.
the only way to exit the blackness is to press the on/off switch twice (one for shut it down and one to turn it on) but it has the problem of the two seconds up and nothing more..
thank you
  • Anonymous Mar 24, 2014
    My screen keeps blacking out after a few seconds it goes dim then turns black... the cameras are view able online and we can see everything work perfectly fine but the monitor itself just doesn't stay on... any suggestions?
  • 24 Answers
Simplest solution may be the screen resolution settings are set higher than the monitor's capabilities. Try lowering the screen resolution and refresh rate in the display properties or try booting to safe mode (press F8 when the Windows splash screen first appears) and see if the LCD will display the windows desktop. It that works, check your video drivers and the screen resolution and refresh rate settings.
If the monitor has the problem in safe mode and/or if lowering the screen resolution and refresh rate don't help then I suspect the a problem similar to one some Dell 17inch LCDs have. On the Dells It is usually caused by a defective voltage regulator transistor in the backlight inverter circuit. Troubleshooting that problem should only be attempted if you have experience at repairing electronic circuitry since it will involve testing individual components and soldering.
Posted on Jun 15, 2008
I gave it back in customer support, it was broken.
they gave me a screen that works (obviously 940n) i dunno if it's another one or the same repaired.
good luck
Posted on Oct 12, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
I have a Vaio PCV-W20, and a few months ago the screen went black. The problem is that now I only get a visible screen for a few seconds and it goes black again. For example this is what I see when the...
Ok try this, at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems. -
Jul 21, 2010 | Sony VAIO PCV-W20 PC Desktop
Screen goes black but still sound
This is inverter or backlighting problem. Can you try switching it on and off quickly for a couple of times and tell me if these '2 seconds' get any longer'. If picture stays longer and longer before shutting down, one lamp needs replaced-if not, please replace inverter board
Jan 15, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Samsung SyncMaster 940N Flat panel Monitor Logo
1,359 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
