Question about Western Digital Computers & Internet
I lost my power cable for my WD5000p032 external hard drive. I purchased a replacement, but i need to know the polarity and the voltage, please help.
SOURCE: Lost ac power supply adaptor for Mli 190 speakers
http://an-labs.com/multi/sw190.html 12vac
Posted on Jan 22, 2007
SOURCE: power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Posted on Nov 24, 2008
SOURCE: power supply for Maxtoe Basics External Hard Drive 500GB
Is 12VDC 2,0A the inner pin is + and the outer pin is -
Posted on Dec 04, 2008
playon186
  • 45 Answers
SOURCE: power supply for logitech driving force steering wheel
It's OK to use a power supply with a bigger current capacity than needed. If you find once with, say, 24V and 1.0A then that's usable - the wheel will draw as much as it needs.
Therefore:
Same voltage (24V)
Same or greater current (=>0.75A)
Same polarity (positive centre) __________________
Same as the Momo Racing Black, positive inside, negative outside.
The G25 power supply output is stronger: 24Vdc, 1.75A, same polarity.
As long as output voltage, polarity, amperes and connectors are the same you should be fine using a compatible unit, if you find one. In your case it would be 24V, 0.75A, positive inside, but if I were in you I'd wait for some American Driving Force owner to confirm this to be completely sure. The American psu model should however be GAD-SLU-240A8, 110V input, same PSU as Driving Force Pro. Take a look at this for more info. I received this from a forum with people that had the same issues as you and I hope this helps. It seems like they're saying that a store bought universal power supply may mess up your wheel so be careful. If this helps, please leave feed back. FIXYA!
Posted on Feb 14, 2009
nonontech
  • 4737 Answers
SOURCE: need to know dc voltage for simpletech external
12 volts Dc and 1.5 ampere with External terminal as Negative Polarity and internal as Positive Polarity.
Good luck
Thanks for using FixYa.
Posted on Jul 06, 2010
I need to know the voltage on the power cord for my 90000-40480-003. Simple Drive Deluxe. Would you know
The drive operates on a 12V, 1.5Amp power supply but the manual doesn't specify polarity(not uncommon). If the power supply has failed you should be able to find polarity indicators on it, if it is lost, it would cost about the same to simply purchase a new enclosure and transfer your drive into that rather than risk getting it wrong.
Given it's advanced age(a senior citizen in the technological world) the drive inside is undoubtedly IDE(or ATA but not SATA), ensure the enclosure you purchase to move the drive into supports IDE/ATA as most these days only support SATA given it's dominance over the past decade. Also given it has passed the point of expecting data loss(computer Alzheimer's), I would highly recommend purchasing a replacement at the same time and copying all of the relevant data to the newer drive as a precaution before retiring the old drive.
Hope this helps,
Chris
Oct 11, 2014 | SimpleTech Simple hard Drive Deluxe....
Seagate external hard drive usb and power adaptor
any power adaptor would do it as long as the voltage is good (usually 12v) and amperes is the same or higher than what's written in your hard drive enclosure (usually 1Ampere = 1000mA) is good enough, some HDDs use up to 2000mA
Usb cable is very easy to find
you can find those at any electronic parts selling or ebay
Please rate
Jul 18, 2013 | Computers & Internet
Lost power cord for my Seagate 9W6044-500 External Hard Drive
Walmart has Universal power adapter starting at $10.95 should solv your problem
Mar 30, 2011 | Seagate (9W6044-500) 160 GB Hard Drive
I have a maxtor 120GB external hard drive but no power supply. How do I get a replacement? I tried a switchable power adapter from a local hardware shop and although I set the voltage to 12v it lights up...
Hi Dave.
The problem you are having is the adaptor you tried is the right voltage but not the correct ampage. You require a 12v dc adapter with a rating of at least 1-Amp. The switchable supply you purchased would be well under the required level, probably 400ma (milli-amp), in other words about half the needed amount. A cable modem power adapter would be sufficiant. If you have one, make sure it is the correct voltage and polarity, positive pole (+) usually the inner pin on the end of the connector. Hope this is of some help to you.
Jan 25, 2011 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Need to know dc voltage for simpletech external hard drive 1tb
Good luck
Jul 06, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Lost my power adapter, need polarity
Output 12VDC 1.5amps or greater 1500mA
Center conductor positive.
Feb 01, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Computers & Internet Logo
347 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
