Question about Samsung T260 Monitor
On monitor T260 I have to scroll right/left & up/down to view the whole window on screen. How do I adjust? The resolution is set at 1920 x 1200
  • dougdawnb Nov 08, 2010
    I have tried every resolution in preferences
  • 656 Answers
Look for the picture rolling in the screen for example if the picture is rolling down sroll it either to right or left when you scroll to right and the picture roll faster then scroll it to left slowly you will the rolling slow down when you scroll again you will see the picture rolling upwards make it in a position its not scrolling on either way
Posted on Nov 09, 2010
  • 712 Answers
Set the resolution at 1024 X 728. If it seems too small, go to the very next higher step. Don't go beyond the one present now.
Hope this helped. If you need any more assistance, don't hesitate to come back to us. Else, if the problem is solved, please DO ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Posted on Nov 07, 2010
I have a wide screen Acer monitor, yet am unable to view my whole web site without scrolling down. I have adjusted the resolution to allow the font to fit on the page, and can see it perfectly with IE,...
Sounds like either your display resolution needs to be set higher or when you bring up firefox after the page loads press and hold the ALT key and Click View, ToolBars and select Menu Bar. This will keep it at the top everytime you open firefox. Now under View you can zoom in and zoom out. You can also select Full Screen. *** Before doing anything did you click the middle box at the top right hand corner of the screen between the - and red x? This toggles between full screen also.
Feb 25, 2018 | Acer X243W 24" TFT wide format screen 24...
My ag neovo e-17da monitor everything in the screen seems to have stretched and the bottom of the screen where the arrow is to scroll up and down i cant see it its like i need to shrink the display a...
Hello Dean,
It seems your windows resolution settings are set wrong, you simply need to adjust the resolution to match the monitor. To do this, open your start menu, select Control panel. When the control panel is open check the top left corner to see if it is in Classic or Category view, if it says Category, click the switch to classic mode link. If you don't see this in the top left look at the top right and look for Category or Large Icon View, if Category is selected select Large Icon by clicking on Category and then clicking Large Icon View in the list that appears.
Once in the proper view, click on Display and depending which version of windows you have select Settings on the top of the properties window(XP or older) or Adjust Resolution from the left column(Vista/7), now find the slider bar for resolution and slide it to 1280x1024. This will set the number of pixels on the screen.
The default and best resolution for this monitor is 1280x1024, if that makes the fonts/icons too small try 1024x768 next and 800x600 last. If the resolution is set too low to see the Ok and Apply buttons simply set the slider bar then press the enter button the first time, then you will be able to see the Ok and Apply if you need to continue adjusting.
Hope this helps FixYa,
Chris
Reply back with your version of windows if you require more specific instructions or pictures of any of the steps.
Jan 02, 2011 | Neovo E-17 17" LCD Monitor
How do I adjust web page to fit display screen
There is the Zoom option in the View menu if you are using IE. You can set it to 100%. With IE8 you can use F11 to set it to display on full screen. Unless you need to set the screen resolution, width and height for your monitor, those should work for you. Pressing Ctrl key and scrolling your mouse will adjust the zoom of web page too, quicker way.
Aug 18, 2010 | Microsoft Windows XP Professional
I installed one gigabyte of memory to replace the virus-eaten original 512 that was currently on this laptop. I ran the OS and now this computer is working very well. The only problem with it is that the...
Try right clicking the desktop then Select "Properties" / Display sould appear, go to setting tab. you may want to write down screen resolution setting as it is now. change as you see fit "more or less" hit ok. It should say your screen has been adjusted, do you wish to save these settings "yes or no" if you do nothing it will go back after 10 seconds. play with it until you get desired look..
Aug 05, 2010 | HP Compaq nx9010
How can I adjust the screen wobble on a alienware aurora m9700 laptop.
Choose Screen ResolutionFor higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpgControl Panel: Display: Settings tab: Screen resolution
May 29, 2010 | Alienware PC Systems Alienware Aurora High...
Monitor screen won't leave presentation mode
Try pressing fn Key + F5 or esc key or windows key.
Thanks
Mar 07, 2010 | Acer Aspire 5004WLMi Notebook
I need to have the resolution set at 1440 X 900 for best viewing. I don't have a clue how to do this. Thanks.
Hi
Please do the following
1) Switch on your PC
2) Right Clickin the middle of the dekstop and click on properties
3) This will open a display properties window, at the top there will be a tab called settings
4) In this windows half way down there will be a option entitled screen resolution, this slider can be pushed to the left or right push to the left until the figures at the bottom read 1440 X 900 pixels
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | eMachines E17T4W 17" Monitor
How to adjust screen resolution with external monitor/hp pavillion dv 2000 laptop
1.Right-click on an empty area of your desktop screen
2.Left-click on Properties at the bottom of the drop down list
3.Left-click on Settings in Display Properties window.
4.Left-click on the 1 monitor icon to adjust the screen resolution for the HP dv2000 LCD screen.
Left-click on the 2 monitor icon to adjust the screen resolution for the external monitor.
5.Go down to where you see the heading - Screen Resolution, and the slider underneath the heading.
Left-click right on the slider, hold the mouse button down, and slide to the Right to increase resolution, to the Left to decrease resolution.
Oct 19, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Everything is large cant see whole page
Go to control panel,display, settings, advanced and make sure the DPI is set to normal, and the resolution on the settings section is set to one supported by your monitor.
If this size is only in browser windows, go to View and adjust the zoom settings...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 20, 2009 | Computers & Internet
Adjustment of the resolution on an IBM Thinkpad 2373
You can adjust your Screen Resolution, by Right clicking on your Desktop - then left click on Properties - here depending on your operating system (windows XP or Vista), you can go to the Display Properties, Settings Tab, there you can adjust your Screen Resolution to the less (lowest) possible number which might be 800x600 or maybe even 640x480 - either way, lower it down to make the icons and text larger in appeareance, this will effect the outcome of many of your applications, but most will allow you to scroll as necessary to view the entire window if necessary.
Mar 23, 2009 | IBM ThinkPad T40 2373 Notebook
Samsung T260  Monitor Logo
50 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
