Question about Skull Candy 1704B1024 Bully MP3 Watch
The battery in my skull candy bully mp3 watch has gone. I believe that there are two batteries, a lithium ion rechargable battery, and a normal watch battery. If this is true, both are dead. The rechargeable battery only holds a charge for a few seconds. I have taken the watch to a store to replace the batteries, however when they look inside the watch, they do not know what to do with it. Also, we cannot get the back to close again after having the store open it. Any assistance would be much appreciative as the skullcandy company has not been of much assistance. This is my favorite watch, and I don't want to have to buy a new one. Please help. Thank you!
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Feb 20, 2011 | Seiko Kinetic watch
I have a Casio 2688 atomic watch and lately it does not hold a charge for a long period of time. It will recharge and then quit within a day.It will hold a medium charge for about 24 hours at most, but...
You likely have a dead battery. Follow the instructions on this web site http://forums.watchuseek.com/f43/how-change-ctl1616-rechargeable-battery-41076.html
it is clear and covers most casio models. Watch closely for the springs when taking your watch apart. You can order the battery online (the best option) but most people that use a standard lithium battery seem to have no problem.
Nov 23, 2010 | Casio PRG-40T-7 Pathfinder
My Seiko Kinetic winds down in one week after weaking a years and is not recharging to run after one day of wearing.
It sounds like that it is time to replace the capacitor with a new Lithium Ion battery. Send it to Timelywatchrepair.com. Go to this web sight
Dec 29, 2009 | Seiko Kinetic watch
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
I cant find a battery for my Fossill Abacus Wristnet AU 4005
Hai,
It has a Powerful rechargeable Li-ion battery so there is no need to purchase extra battery kits!
Aug 25, 2009 | Fossil AU4003 Wristwatch
What type of battery goes into Casio G shock MTG900, Module 2638
CTL is the designation for a rechargeable secondary battery. The CR is a primary disposable battery and is a 3 volt cell. The CTL1616 while the same size as the CR1616 function completely differently and are not interchangeable. The CTL1616 is 2.3 volts and is recharged by solar or light or kinetic movement. The CR1616 is 3 volts is not rechargeable and will not function properly in a time piece designed for a 2.3 volt circuit. There is only one manufacturer of the CTL1616, Panasonic and they sell through Casio parts distribution.
Jan 22, 2009 | Luminox 3102 (Size: ) Watch for Men
Seiko Kinetic Watch model 8D0557
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at TimelyWatchRepair.com
Oct 20, 2008 | Seiko Kinetic watch
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Skull Candy 1704B1024 Bully MP3 Watch Logo
89 people viewed this question
Top Skull Candy Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Skull Candy Watch Expert? Answer questions, earn points and help others
