Question about LG Washing Machines
My LG frontloader 7.5KG washing machine WD-8023FB has sprung a leak from the front panel just under and slightly to the left of the control panel. Clear water leaks like a stream when the washer has filed and is rotating. There are no suds leaking and no other existing problems as it washes well. Please tell me its just a seal and i can get a new one.
  • himelh Nov 07, 2010
    I used online tips from your gurus about the gunk building up in the dispenser draw and removed it cleaned it as best i could with a paper towel and it seems to be improved, hopefully fixed. thanks!!
catriver
  • 878 Answers
SOURCE: LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Posted on Aug 14, 2006
  • 92 Answers
SOURCE: LG WM1814CW - Water/soap Leaking Under Washing Machine onto Floor
I suggest taking the top panel off (2 screws in back leave the plastic piece on the lid). push hard back and lift lid off. now you can look in from the top. look for soap residue to see if water is leaking down the side of the cabnet. if none is evident check hoses. what makes you so sure its in the middle/back. if you only notice it during the wash cycle you may have to go in back and take off the panel check around the bearing behind the pulley in the tub, could be leaking
Posted on Feb 10, 2008
jtate9
  • 68 Answers
SOURCE: water leaking from under the front of the washing machine
The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Posted on Jul 29, 2008
futureloginn
  • 734 Answers
SOURCE: My front loader is leaking water from the bottom
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
Hi I've got Washing Machine LG WD-8023FB front load, and SE or 5E alarm is on and machine is not working. What is that alarm for?
the alarm is indicating that the machine is not working that u should restart it or better still u check the mabual for p[roper operation
Jun 24, 2011 | LG Washing Machines
Hi there My frontloader washing machine display
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock.
Mar 08, 2011 | LG WD-1280FHD Front Load Washer
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
LG WD-12124RD How do I remove the front panels?
Hiya,
most machines now open from the back you will find 2 or 3 screws/bolts at the top holding on the top section if you un screw those then slide the top back slightly it should unclip allowing you to take off the top this should expose some more screws or bolts that will be holding on the front & sides, if your machine is leaking from the front you could have a leaky door seal too so you may want to check that before starting to take it apart.
Hope this helps
Apr 23, 2010 | LG WD-12124RD Front Load Washer
LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Jul 23, 2009 | LG WM2277H Front Load Washer
LG Washing machine
its hard to know without hearing it,is there somthing stuck between the drums try taking the belt off and turning the drum by hand.sorry i cant be of more help
Mar 04, 2008 | Washing Machines
Lg washing machine 1289 fhd
The operating pressure is 4.5 - 116 psi.
Where is the leak?
Feb 08, 2008 | LG WD-1280FHD Front Load Washer
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
