Question about Filter Queen Majestic Canister Vacuum
The red light by the on and off switch turned on . what does that mean
    Novelist:
  • 147 Answers
Usually it indicates a low suction issue. Wether the hose is clogged, or either one or all 4 filters need to be changed. Usually the cone and the circular filter above the plastic cone should be replaced.
Good luck,
Mark
Posted on Nov 07, 2010
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
Dyson dc28 animal red light flashing and no suction
Clean any debris from around the brush bar. If this doesn't solve the problem you may need to take it to a qualified repair person
May 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
What does the question mark light mean?
There is no bag in the vacuum, or the bag is not placed in the vacuum correctly.
In the lower corner of the bag holder near the door is a little black switch, this switch must be pushed in for the vacuum to run. This is a safety so you cannot clean without a bag in the machine.
May 19, 2009 | Electrolux Epic 6500 Vacuum
On switch lite burnt out need replacement
There is no light bulb in the switch of the machine. It is simply light shining through the red button that gives it that effect/illusion. If you are able to turn on your machine without any problems it is working as it should. If the power switch is not engaging and the vac is not turning on at all, that's a different issue. In that case call the Dyson Helpline so that they can refer you to an authorized dealer in your area who will fix the switch for you.
Mar 12, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Filter Queen Majestic Canister Vacuum Logo
488 people viewed this question
Top Filter Queen Vacuums Experts
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
