Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you install the deflector shield spring on a 42" deck?
  • 7 Answers
SOURCE: deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
Posted on Sep 05, 2008
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
kel1guy2002
  • 3740 Answers
SOURCE: How do I install the
Hi and welcome to FicYa, I am Kelly.
You will need to make sure that you have items 21 - 29 of this diagram: Scroll way down 75% until you see the deck and belt, then look at item 27 the deflector shield.
http://www.hammerwall.com/Manuals/Craftsman/Description/917.288031/Craftsman%20Lawn%20Tractor%2017.5%20HP%2042%20Inch%20Mower%206%20Speed/L0807249/
It is a matter of sliding the bolt throught bracket on the mower deck and making sure that the shield safety switch is actuated. (Flip up)
I also read the owner's manual (no help!). The only thing about the shield is on page 14 stating to make sure it is in place.
If your missing the hardware to install the deflector shield you can go to http:www.searspartsdirect.com and enter your model number in the search bar. You have to choose model search then click (go).
You will get this diagram if you choose mower deck:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917288030/0247/1509200/P0905008/00007?blt=06&prst=&shdMod=
Thanks for choosing FixYa,
Kelly
Posted on Apr 30, 2011
rycgl
  • 1545 Answers
SOURCE: I need to see a
Copy your model number onto this parts and diagrams page for MTD and as you can see from the existing parts diagram, you will have what you need. I would have but I needed the model number.
http://www.partstree.com/parts/?lc=mtd_pro&mn=13AT605H718+%282006%29&dn=6902073C0001
Posted on Jun 12, 2011
Testimonial: "Thanks for the link,"
I need to installhow to install a new deflector on Craftsman mower model 917273130?
Very simple. The 6 inch or so pin that holds it on is retained by a clip on one end. To remove clip use a pair of pliers. If you work steadily and carefully you will be able to reuse this clip. After removing clip, pull the pin out. Old deflector and spring be removed now. To get the spring right you have to try it in position before installing it. Just remember that the spring is holding the deflector down so when you are done installing, when you pick up on the deflector there is pressure holding it down. Don't put the pin clip on until you verify the spring force is correct because getting that spring clip off is the Hardesty pay off the job.
Oct 11, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replace spring on grass deflector
you have to hold the spring and deflector in the loaded position (forcing against the spring force) while you feed the pin thru the deflector and spring and back thru the deflector and intor the deck bracket.
Jul 24, 2014 | Craftsman Garden
How do I replace deflctor shield
You have to hold the spring and deflector in the loaded position (forcing against the spring force) while you feed the pin thru the deflector and spring and back thru the deflector and intor the deck bracket.
Jul 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How spring goes on deflector shield
Please wear eye protection for your safety before performing this task since there is a spring that is under load! Take a pair of side cutters and cut the one way lock washer located on the font side of the shaft. (Facing Towards Front of Tractor). It should be black in color. Take a pair of pliers or vise-grips and pull and twist the rear part of the shaft that goes through the plastic deflector and work the plastic deflector up and down while you work the shaft out. As you're working the deflector shaft out, take caution as the spring will pop out of place. To install new deflector, place spring between plastic deflector and align it up to the hinge openings on the deck. Make sure the "L" tab is inserted in the open slot of the plastic deflector. Tilt the plastic deflector towards the back side and start to insert the deflector shaft from the back and wedge it in about close to half way in. Take the front part of the spring that has the rubber tab (to protect deck paint) and twist it counter clockwise so the rubber tab is pointing towards the left side of the deck. Push down on the plastic deflector assembly and continue to work the deflector shaft all the way through to the font hinge opening. Once the shaft has passed all the way through the hinge opening, take a 9mm or 10mm deep well quarter inch socket and tap the new one way lock washer that can be purchased at your local hardware or Home Depot location. Use a soft mallet hammer to do this so you won't damage the chrome finish on the socket. Good Luck and Let Me Know How it Turns Out.
Aug 31, 2013 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Lt1000 manual
I have the same outfit, what deflector are you talking about?
Jun 05, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How does the sping go on the grass deflector?
U need a diagram ver hard to explain but try this line up your spring in the grooves of deflector put ththem agaibst the deck in between whereyou will nect slide the long pin that goes through the spring and the deflector you can find a diagram on sear parst online web site type in your serial number and model or look in your manual it takes about 2 minsto installjust position correctly and slide in pin ask for second pair of hands
Joe
Oct 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I install the deflector shield on a Craftsman LT1000 lawn tractor, model # 917.274351?
Have you checked if it has a nut on the other end which is just turning round with the bolt ?
Sep 01, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I install the deflector shield on a Craftsman riding mower, model # 917.288031?
Kelly
Apr 30, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
362 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
