Question about Frigidaire ATF6000ES Front Load Washer
My Frigidaire front load washer is turning on but no water pumping in. A metal (possibly magnetic) rectangular block fell out from somewhere before this problem started.
ngfam1
  • 639 Answers
SOURCE: where does the magnet belong
Call Service and have them come out.If it's new your our under warranty!
Good work done here.
A&E Factory Service
Nation Wide
7days/24 hours
They do Frigidaire warranty work.
Thank You for asking!
Please rate my, solution solved in this fixya site!
Neil
Posted on Aug 24, 2008
SOURCE: Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Posted on Nov 06, 2008
onthejob5130
  • 640 Answers
SOURCE: My Frigidaire Front Loader Washer will not turn on at all???
it came from your dispencer ..it activates a sensor on the unit right side,,,,take your dispencer out turn it over and that magnet goes on the left side when dispencer is right side up....yes that magnet is neeeded to start unit...onthejob
Posted on Jan 17, 2009
  • 20 Answers
SOURCE: Magnet came out and now washer won't run
on the under side of the dispencer, remove it, flip it over, fit it in with some glue, as far toward the inner part as possible, put it back, try the washer, if it still doesnt fill, try pulling it out a little and see if that works, if it does this is the amount you need to move the magnet back.
Posted on Feb 13, 2009
SOURCE: Frigidaire gltf2940e front loading washer - dispenser drawer magnet replacement
When you are looking at the drawer, the magnet stands upright on the far right side just inside the outer front casing about halfway down. There is a small plastic clip that holds it in place. You don't need to take anything apart to reinsert the magnet, just open the drawer, but it may be easier to see the location if you pull the drawer all the way out of the hole.
Posted on May 16, 2009
Our magnet fell out, where does it go
If you are talking about a small, rectangular magnet, about a 1/16" think or so, it goes in the detergent dispenser drawer. Looking at the front of the drawer, right side, a little behind the front. This magnet triggers a ( or should if its not falied) a magnetic reed switch which allows the washer to operate only if the drawer is closed.
If you take the drawer out, and remove the front, you will see where it goes.
Apr 26, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Mar 20, 2009 | Frigidaire Washing Machines
Feb 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Gallery trouble
Took off the front panel, opened up the hoses to the pump, found a small metal magnet from my son's pocket that had been stuck in the pump. Once it was removed, the washer worked just fine.
Nov 05, 2008 | Frigidaire GLWS1233A Top Load Washer
Magnet
if it's a small rectangular magnet that appears, in our case, fell out, when you add detergent, softener, etc...the magnet goes on the right hand bottom corner of the drawer face, straight up and down, not sideways. this is evidently some type of sensor allowing the washer to start. we had an error code of "ddo" when the magnet fell out.
Sep 04, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
