Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I am having trouble connecting my new Macbookpro to the wireless network in my home using a D-Link router (WBR1310). It doesn't seem to like the password which I have on record.
  • D-Link Master
  • 7,733 Answers
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
  • How do I find my routers IP Address, in Windows XP?
  • How do I reset my router back to the factory default settings?
    (NOTE: To reach the configuration page of your D-Link router in Mac OS, you will need to use a Java compatible browser such as Firefox or Camino.)
    (NOTE: Some routers have a "Captcha" graphical login option. This option can be disabled in the advanced options of the routers configuration.)
  • Posted on Nov 07, 2010
    How to secure a d-link wbr1310 wireless router
    Setting up security on a WiFi router is quite simple and straightforward.
    All you need to do is login to the router and set up a Network Name (SSID) which will be used to identify the network and then add a passoword to secure the Network.
    Once done, any device that connects to the WiFi Network will need to authenticate with the password that has been specified on the Router. This will prevent unauthorized access to your home wireless network.
    Sep 08, 2010 | D-Link 802.11g Wireless Router WBR-1310...
    Everytime my wife's iphone connects to our home network, my laptop looses the internet connection and goes to a local connection only. I have to disconnect and reconnect and everything works fine.
    I find that when it comes to iphones and home wireless networks, that using 64bit encryption is the best. I'm not sure what you are using now, but give this a try.
    May 03, 2010 | D-Link 802.11g Wireless Router WBR-1310...
    Lost wireless connection. Diagnosis said network connection o.k but cable not connected to network adapter for local area connections. cheked and all cables connected even changed blue line ethernet...
    Check if the wireless works by directly connecting to the Lan port and the system. If it works, you may have to check for the Wireless Home Setup. Check if there are changes made to the Freequencies. 802.3 g usually gives max range. In case you are working at a distance which the signal wouldnt cover, the system can show network not detected. Also try to work on a Manual Address mode than DHCP and find if the network is getting detected. Check if the WNC is enabled and if working on DHCP, try do a tcp ip reset using the command from the command prompt... by using the command ipconfig /release.
    and then ipconfig /renew
    if the ip is renewed successfully, the wireless router is allocating the new tcp ip address and your network should work. Good luck.
    Feb 13, 2010 | D-Link 802.11g Wireless Router WBR-1310...
    I have a d-link router. i can connect to my
    The wireless card is configured for your D-Link at home.
    You need to configure your laptop's wireless card for the wireless settings at work too (ie the SSID and encryption etc.). Contact the network manager at your work for the wireless configuration so you can configure the wireless card with these settings.
    It maybe possible to setup different profiles on the laptop's wireless card, one for home and one for work so you can just click on the correct profile depending on your home or work location.
    Dec 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
    Since upgrade MacBookPro to Snow Leopard it will not wireless connect to D-Link DSL 604T. Is there a firmware upgrade for this wireless router for use with MacBookPro running Mac OSX 10.6.1 please? My...
    When you try to connect to the wireless network, Do u get any error message ?
    You said that your other wireless is working properly.
    that means the router is working properly.
    Check the wireless security settings of the router. Do not change the wireless settings, just check the wireless settings.
    You will need to open the Web Interface of the router.
    Click Here for more info
    Oct 22, 2009 | D-Link DSL-G604T Wireless Router
    I have the WBR1310 D-Link wireless router. I
    I would try one or both of the following:
    1. Update any drivers or software for the D-Link router.
    2. Update the firmware of the router (see page 38 of the user manual for instructions to do this). -- you can download the manual at http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310 if you dont have it.
    Hope this helps.
    Oct 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
    Wireless Home network will not stay connected to internet
    So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
    Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
    Have a microcom ad2730 wireless router Vista-based laptop problem
    - If you have a secured wireless network through your router, make sure you type it correctly on Vista laptop.
    Mar 02, 2009 | D-Link 802.11g Wireless Router WBR-1310...
    NO INTERNET CONNECTION
    if u have lights on adsl and the internet it indicates tat u got internet connection, then u need to check the connectivity bw ur computer and the router, for  if vista u needed to update the latest driver for it if not resolved get back with lght status of the router and how u r trying to connect no command needed cottect with ethernet cable and chk the connectivity
    Nov 01, 2008 | D-Link 802.11g Wireless Router WBR-1310...
    I am having trouble connecting my d link router to my new computer tower
    My wbr 1310 is horrible i have it set up so that i can use my ps3 online but when i go to network status it is at about 30-60 strength i dont no how to fix it. When i play call of duty 4 it takes forever to set up game but when im the host i get in right away. SOMEONE PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Jul 14, 2008 | D-Link 802.11g Wireless Router WBR-1310...
    D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
    100 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
