Question about Maytag Neptune FAV6800AW Top Load Washer
I heard my Maytag Neptune shake hard today when a load of laundry was going. I assumed the spin cyle got got offline for a second. The washer seemed fine. Then I did another load of laundry. While it was filling with water I pressed pause to add an item. When it unlocked and I opened the lid the water was still filling (which has always shut off in the past). I didn't think much about it at the time. Probably half way through the cycle we left the house. When I returned the laundry was done, however water was all over the rug and had soaked through the floor to the basement. We are trying to find out what may have caused this. Please advise.
Do NOT call the Blue guys from Sears,,,he told me it would cost more than $2000 to fix a machine that will wash but not spin or drain ( I could get it to do both by pushing certain buttons). It is now outside and I have a used $215 washer that is doing great.
Posted on Nov 07, 2010
The washer shakes violently then the off balance sensor trips when a load is in the washer.
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition...
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
Since I haven't heard back on this in over a week, I will assume it's been resolved with the clarification questions.
Jul 04, 2008 | Maytag MAH6700AWW Neptune Front-Load...
yes, but 900 is a little high for my area. is it loud in spin now? the seal can be replaced for about 50-80 part labor is 1 to 3 hours. if you just smelled the smoke and it is not loud you are ok for a long time, reduce load size and it will probly be ok for some time
May 16, 2008 | Maytag Neptune Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
