Question about Cell Phones
My iPhone 4's microphone seems to be intermittently working. Sometimes (at least 33% of the time) when a call is connected, the other party cannot hear me. I can hear them just fine. I am not connected via blue-tooth (or any other fashion) to any external devices. Thank you
    Sergeant:
  • 389 Answers
The iPhone4 has just come out and apple is still working out some of the kinks. I suggest you take it to the nearest Apple store and explain the problem and they are very nice about it, they will more than likely fix the problem for you. Good Luck
Posted on Nov 07, 2010
How do i fix my iPhone so the receiver can here me when i talk
1.Unplug anything plugged into the headset jack.
2.If you're on a call and holding your phone next to your ear, speak into the microphone and make sure you don't block it with your fingers or shoulder.
3.If you're using a screen protector or case that covers the microphone, remove it. Clear any debris from the microphones.
4.Restart your device.
5.Update to the latest version of iOS.
Test the microphone
To find out if there is an issue with the microphone itself-and not the app you're using or your cellular connection-test the microphone with the built-in Voice Memos app. Speak into the microphone and then play back the recording. You should be able to hear your voice clearly.
*If you can't hear your own voice the microphone is not working properly, you should replace the piece of hardware.
Jan 27, 2015 | Apple iPhone 4 Black Smartphone
In iphone4 speaker sound not working
The speaker is sometimes disabled when you connect the 30 PIN sync chord. If the 30 PIN connector is damaged, it can cause the speaker to not work, or to work intermittently. Try using a thin object (like a safety pin or something similarly thin, preferably something non metallic and non conductive) and gently jiggle the 30 PIN connector on the iPhone while playing a sound, (like a music file in the music player). If the sound starts playing again you have found the cause of your problem. Unfortunately if the connector is the problem you will need to be careful in the future when you disconnect your sync chord.
This is most often caused by placing the iPhone into a sync port designed for the iPhone 3GS and earlier models. The iPhone 4 and later needs support to keep it from straining the 30 PIN connector on the iPhone 4 or iPhone 4S.
Good Luck.
Apr 08, 2014 | Cell Phones
Use on laptop creates noise & frozen picture 4 person talking to
Its not due to the laptop, the other person is viewing you on the internet (Yahoo/Msn etc) so the Video might get frozen sometimes or may be a lot many times depending on the bandwidth or the server load.
The voice is due to the microphone you are using, you can use microphone with noise reduction technology with some noise reduction utility.
Regards,
Shrey
Oct 10, 2009 | HP KQ246AA Deluxe Webcam
Other person can't hear
It could be connection. The cable might not be sending the right information to the computer.
It might also be their computer. Ask them to try restarting their program. If it doesn't work try fiddling with the wire.
If you have a built in mircophone, then I suggest contacting your coomputer's manufacturer and ask for a repair.
Jul 06, 2009 | Yahoo Messenger
My iphone's microphone is not working sometimes.
Try resetting your phone, if this does not work then it is probably not an internal problem.
Most often this is from simply debris getting clogged in the microphone... seeing as the microphone is a miniscule hole, a small piece of debris can cause major problems.
To fix this:
1. Find the microphone, (it is the tiny dot next to where you plug in your earphones)
2. Get a needle and poke around in it, tip it upside down, and any lodged debris should fall out.
3. Test it out.
Tell me if this works or not.
Dec 11, 2008 | Apple iPhone Smartphone
IPhone 3G Bluetooth microphone volume to low
This is a Normal problem, remeber the echo is for the mircrophone is in the same place like the speakers, & dont have a noice cancelation system, I recomended to use a bluetooth earphone
Nov 14, 2008 | Apple iPhone 3G
Is H700 compatible with the iPhone?
Here is a straightforward procedure to "pair" the Motorola H700 bluetooth headset with an iphone
1. Turn off the headset by folding the microphone.
2. On your iphone, go to settings-->General-->Bluetooth-->tap tp turn ON
3. To activate your headset, hold down the center button and keep it pressed while you fold out the microphone.
The iphone will immediately detect the device and state "not paiired"
Ignore this message and go ahead and tap on the headset menu displayed on th eipjone screen. You will e prompted fot a security code. Please enter 0000. The iphone will confirm that the devices have een paired successfully.
You arer done! To verify, try placing a call from the iphone and you will see a new menu on iphone asking you to choose the headset H700 or speaker phone.
Step 3 is the most important step in getting the two devices to talk.
Apr 23, 2008 | Motorola Mobility H700 Wireless Headset
Cell Phones Logo
256 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
